Hello world,
I recently visited a EN-UK page on CTSFO.
After opening the page a few ten seconds or so, the page redirects to https://en.0wikipedia.org/wiki/Counter_Terrorist_Specialist_Firearms_Officer
uBlock was able to block some elements to be loaded.
When I opened the url in Edge in a private window (accidentally, I wanted to open an application guard window), a small window opened in the middle of the screen for a brief second. Might have been something running in the background or the website loading something. Edge also runs uBlock.
I ran dns info with Flagfox on this but couldn’t get much.
Can someone tell me what is going on? Do I need to stop my extension?
Alvast bedankt.
My Google search lent me this as the most common answer
From what I understand, 0wikipedia.org is an umbrella domain. Even if the final redirected domain (in this case wikizero.biz) shuts down or gets blocked, 0wikipedia.org will always redirect to a domain that works. If I change 0wikipedia.org to wikizero.biz, there is no guarantee that wikizero.biz will stay up and redirect to another domain if something were to happen to it. 0wikipedia has been working for years now and it’s the one Turkish people are most familiar with. That’s why I’m a bit hesitant to remove it completely and replace it with wikizero.biz.
That’s all I can find so maybe I have a thought it could be a DNS error. Have you considered switching to quad9 or cloud flare and doing the DNS w/DNSSEC enabled or better yet since that looks like Firefox using cloud flare DNS over https and seeing if the same thing occurs?
Just spur of the moment thoughts
I’m also running TOR proxies.
Also using a VPN, but it does not make a difference because I was redirected without it too.
thats not how you use DNS over https. Quad9 provides directions.
As for the DNS records of the page I just get this from kdig using my own DNS server: (which will be far more complete than flag fox can be)
❯ kdig -d ANY +noall +answer +multiline @tld.net 0wikipedia.org +dnssec +tls-ca +tls-hostname=tld.net # +tls-sni=tld.net
;; DEBUG: Querying for owner(0wikipedia.org.), class(1), type(255), server(tld.net), port(853), protocol(TCP)
;; DEBUG: TLS, imported 148 system certificates
;; DEBUG: TLS, received certificate hierarchy:
;; DEBUG: #1, CN=tld.net
;; DEBUG: SHA-256 PIN: YIV4gOZ9GTejDQpqtFW5pIfJlQBcZem4tLEYx3rTaa8=
;; DEBUG: #2, C=US,O=Let's Encrypt,CN=R3
;; DEBUG: SHA-256 PIN: jQJTbIh0grw0/1TkHSumWb+Fs0Ggogr621gT3PvPKG0=
;; DEBUG: #3, C=US,O=Internet Security Research Group,CN=ISRG Root X1
;; DEBUG: SHA-256 PIN: C5+lpZ7tcVwmwQIMcRtPbsQtWLABXhQzejna0wHFr8M=
;; DEBUG: TLS, skipping certificate PIN check
;; DEBUG: TLS, The certificate is trusted.
;; TLS session (TLS1.3)-(ECDHE-SECP521R1)-(ECDSA-SECP384R1-SHA384)-(CHACHA20-POLY1305)
;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 11493
;; Flags: qr rd ra; QUERY: 1; ANSWER: 5; AUTHORITY: 0; ADDITIONAL: 1
;; EDNS PSEUDOSECTION:
;; Version: 0; flags: do; UDP size: 1472 B; ext-rcode: NOERROR
;; ANSWER SECTION:
0wikipedia.org. 498 IN A 198.35.26.96
0wikipedia.org. 513 IN AAAA 2620:0:863:ed1a::1
0wikipedia.org. 12537 IN NS ns2.0wikimedia.org.
0wikipedia.org. 12537 IN NS ns0.wikimedia.org.
0wikipedia.org. 12537 IN NS ns1.wikimedia.org.
;; Received 150 B
;; Time 2021-10-08 03:49:55 MDT
;; From 2600:3c04::f03c:92ff:fec6:2030@853(TCP) in 31.3 ms
â–‘â–’â–“ ~ â–“â–’â–‘
I dont see anything out of the ordinary. It points to wikipedia’s name servers
My presumption here is the redirect might be coming because you are using TOR. Does the redirect happen when you don’t have the VPN on and when you’re not using TOR
That’s my presumption If this is suddenly happening then kind of wait and see until maybe a day from now and if it’s still happening all of a sudden then maybe there’s a routing issue with your ISP I really couldn’t tell you this is a very difficult thing to diagnose and given all of the stuff that you are running it only adds to the difficulty. My suggestion is to remove all those things try to access it on the clear web with a clear connection and if it still occurs then then maybe you can say it’s your ISP or the routing. If it doesn’t occur then well then we kind of know that one of the things on your system is causing it
I always have TOR enabled. Only way I can access the internet.
I noticed that I had forgotten to include the DNS settings in my Windows network adapters.
I added Quad9 to the Wifi adapter and VPN adapter.
If I remember correctly I already included quad9 dns on the router.
The page still sends a GET signal and then fails to load in.
Timed out
Okay quad 9 is pretty good I’ve never really had an issue with them so I can’t really say it’s them that’s doing it.
This is difficult If tor is the only way you can access the internet then I actually believe the whole story that the internet is leaving me to believe when I Google this.
The zero URL is there to get around censorship and is perfectly normal especially since it’s pointing to Wikipedia’s name servers. Is there a problem loading the page specifically when you have to load on that version of the page or what’s going on that’s making you concerned about the redirect?
Edit: ahh so it times out when loading. Interesting
I’m not entirely sure and without being in your specific situation I don’t think many other people here are going to be sure either. Google gives nothing so I can understand your frustration
The only other hit I’m getting on Google right now for you is that it’s part of zerowiki. Which is an extension but I don’t know if you’re running that?
Yes, recently added a new batch and removed old Add-ons from Firefox, to keep up with security and deny cdns, remove and block trackers and overall improvements. Worried some add-on might be malicious or compromised as I recommended a list of some of these to a friend.
I have had this for quite a while (this setup), never noticed wikipedia to redirect and clear out the backlog like I would’ve visited the page directly from ddg.
did some more lol Digging for you
❯ kdig -d ANY +noall +answer +multiline @dns.quad9.net 0wikipedia.org +dnssec +tls-ca +tls-hostname=dns.quad9.net # +tls-sni=dns.quad9.net
;; DEBUG: Querying for owner(0wikipedia.org.), class(1), type(255), server(dns.quad9.net), port(853), protocol(TCP)
;; DEBUG: #1, C=US,ST=California,L=Berkeley,O=Quad9,CN=*.quad9.net
;; DEBUG: SHA-256 PIN: /SlsviBkb05Y/8XiKF9+CZsgCtrqPQk5bh47o0R3/Cg=
;; DEBUG: #2, C=US,O=DigiCert Inc,CN=DigiCert TLS Hybrid ECC SHA384 2020 CA1
;; DEBUG: SHA-256 PIN: e0IRz5Tio3GA1Xs4fUVWmH1xHDiH2dMbVtCBSkOIdqM=
;; TLS session (TLS1.3)-(ECDHE-SECP256R1)-(ECDSA-SECP256R1-SHA256)-(AES-256-GCM)
;; ->>HEADER<<- opcode: QUERY; status: NOERROR; id: 37291
;; Flags: qr rd ra ad; QUERY: 1; ANSWER: 0; AUTHORITY: 4; ADDITIONAL: 1
;; Version: 0; flags: do; UDP size: 1232 B; ext-rcode: NOERROR
;; Received 511 B
;; Time 2021-10-08 04:08:51 MDT
;; From 2620:fe::fe@853(TCP) in 22.1 ms
Looks like quad9 blocks or otherwise does not answer or returns NULL for DNS on 0wikipedia.org
It might be quad9?
I run quite a few extension:
[redacted]
Hmm that is an extremely long list. I did some DNS poking all I can ascertain from my end is that DNS isnt directing to 0wikipedia.org to grab the closed mirror on QUAD9 … Thats about the end of where my ideas are at. I hope you or someone else has better luck. Sorry
Phased has given some great advice, but perhaps checking without a browser might help?
Like doing a ping/trace route from From Windows’ CMD/Powershell, and seeing if it will a: DNS lookup Wikipedia.org and b:connect to it? Or even if it resolves to 0wikipedia or whatever?
DIG would probably be better, as demonstrated by Phased as well, if you can do that from a windows command line?
I do not know how to do the other things.
I tried to replicate on chrome (no extensions) and firefox with duckduck go and ublock extensions
didn’t get redirected, but I’m in south america and have no vpn enabled
although my windows ps ping function is only giving me timeouts both on local (same country) websites and google and wikipedia
pinging pt.wikipedia.org actually made the requests to dyna.wikimedia.org
Summary
I disabled " Remove Link Tracking" and it stopped redirecting.
I’ll report this for Mozilla to figure out.
Edit, the page redirected again, I don’t know what happened there that it stopped…
Edit: now I disabled some more. I refreshed the page (F5) few times and nothing showing up in the network log. I’m going through the addons now.
Edit:
I’m not sure, but for some reason a paypal page is being opened.
I think I solved this mystery. Still gonna make sure and see if it is right.
So I disabled DuckDuckGoify and Wikipedia does not redirect.
