[SOLVED] Weird issues with ram
this morning my wife's PC wouldn't post and i did some troubleshooting before i got stuck
so idk if the mainboard is screwed up or what but the PC will only boot with one stick of ram out of the 4 sticks of ram that work
which means i tried 1 stick in each slot all work fine but when i start to add sticks it wont even post at all the bios splash screen wont even come up at all
does this mean the board has a short in it or what b/c this is confusing me
Specs
Asrock 990fx extreme 3 motherboard
FX-4300
8gb of Gskill Ripjaw x DDR3-1866
Sapphire Radeon R9 280x
nvm i fixed the problem i reset the bios using the clrcmos jumper and now everyhting works again :D
