So I was wondering, would there be any potential risk of damage if a VirtualBox virtual machine image is brought/used on multiple platforms? Is this even possible, or is that not really how that works?
For example if I try loading a virtual machine image in macOS, or Windows 10, that was originally initialized in Windows 7.
It shouldn’t. The VM shouldn’t even know that it’s a VM. As long as the hypervisors support the same virtual hard drive type (vdx, vhdk, qcow2, etc).
Thank you!
Just tried with Windows 7 and macOS and it works great.
Was having issues just trying to get one up and running with Windows 10 and that was a train wreck.
I’ll keep at it, and hopefully get it working.
This is awesome!
Recently set up a VM on a friend’s pc with Win10 and VirtualBox. Had some wierd issues with networking, Wel he still gets some from time to time and then he has to restart the host to get networking up and running again.
For a while I actually had a dual boot system with two different host OS’s (Windows and Linux) with a 3rd shared file system with VirtualBox VMs. I was actually able to share the VMs regardless of which OS was booted. I had to change some default paths in the VirtualBox GUI, but it actually worked fairly well.
