I just upgraded my stable running Fedora 28 to Fedora 29, I know fail. After rebooting i wasnt able to log in to 29 with the new grub entry, created by the upgrade. So I tried one of my older Fedora 28 entries, which worked but strangely to fedora 29. First I wasnt sure if it was really 29 so I checked /etc/…/… not sure right now about the path which clearly stated twenty nine.
A little bit baffled i decided to update grub. Now no entry is working anymore and my root account isnt unlocked so the rescue entry isnt good either, which means I managed to lock myself out … again. Any suggestion?
yes i was able to access my system and switch to multi-user.target. Narrowing my problem down a little bit. My graphical target is not starting, neither is the X Server which explains the hanging boot on all grub boot entries.
B4 my update I had the Nvidia drivers installed and nuoveau blacklisted. Meanwhile I upgraded the Nvidia drivers to the newest version 415,…
I used the graphical interface from my gnome desktop.
I was checking the documentation but wasn’t able to find any similar issue to mine. I guess it has something to do with the IOMMU passthrough and/or my GPU settings that got the upgrade to hickup
