[SOLVED] Unable to connect to libvirt qemu://system after changing to kernel module
Hi there,
I’m trying to change my setup to use the kernel module instead.
I’ve been following the docs but I’ve encountered a problem.
I’ve made the necessary changes but now Virt-Manager fails to connect to libvirt.
Output of ls -l /dev/kvmfr0:
crw-rw---- 1 ian kvm 510, 0 Oct 25 08:44 /dev/kvmfr0
My cgroup_device_acl block in /etc/libvirt/qemu.conf:
Screenshot_20241025_085459
Contents of /etc/apparmor.d/local/abstractions/libvirt-qemu:
Screenshot_20241025_085637
Honestly don’t know what went wrong. I’d be happy for any advice! :slight_smile:
Update: still haven’t found a way to make it work.
I’ll try to post as much information as possible, hopefully someone spots the error in my configuration. I’d love to make this work!
virt-manager's full error message when starting the VM
Unable to connect to libvirt qemu:///system.
Cannot recv data: Connection reset by peer
Libvirt URI is: qemu:///system
Traceback (most recent call last):
  File "/usr/share/virt-manager/virtManager/connection.py", line 923, in _do_open
    self._backend.open(cb, data)
  File "/usr/share/virt-manager/virtinst/connection.py", line 171, in open
    conn = libvirt.openAuth(self._open_uri,
  File "/usr/lib/python3.12/site-packages/libvirt.py", line 147, in openAuth
    raise libvirtError('virConnectOpenAuth() failed')
libvirt.libvirtError: Cannot recv data: Connection reset by peer
Full xml of my VM:
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>Gaming</name>
  <uuid>b7f5a6fa-a759-47a9-8512-21550245c11a</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/10"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <hugepages/>
  </memoryBacking>
  <vcpu placement='static'>8</vcpu>
  <iothreads>1</iothreads>
  <cputune>
    <vcpupin vcpu='0' cpuset='1'/>
    <vcpupin vcpu='1' cpuset='2'/>
    <vcpupin vcpu='2' cpuset='3'/>
    <vcpupin vcpu='3' cpuset='4'/>
    <vcpupin vcpu='4' cpuset='6'/>
    <vcpupin vcpu='5' cpuset='7'/>
    <vcpupin vcpu='6' cpuset='8'/>
    <vcpupin vcpu='7' cpuset='9'/>
    <emulatorpin cpuset='0,5'/>
    <iothreadpin iothread='1' cpuset='10-11'/>
  </cputune>
  <os firmware='efi'>
    <type arch='x86_64' machine='pc-q35-9.1'>hvm</type>
    <firmware>
      <feature enabled='no' name='enrolled-keys'/>
      <feature enabled='no' name='secure-boot'/>
    </firmware>
    <loader readonly='yes' type='pflash'>/usr/share/edk2/x64/OVMF_CODE.fd</loader>
    <nvram template='/usr/share/edk2/x64/OVMF_VARS.fd'>/var/lib/libvirt/qemu/nvram/Gaming_VARS.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <relaxed state='on'/>
      <vapic state='on'/>
      <spinlocks state='on' retries='8191'/>
      <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
      <reset state='on'/>
      <frequencies state='on'/>
    </hyperv>
    <vmport state='off'/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='off'>
    <topology sockets='1' dies='1' clusters='1' cores='4' threads='2'/>
    <cache mode='passthrough'/>
    <maxphysaddr mode='passthrough' limit='40'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
    <timer name='hypervclock' present='yes'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type='file' device='disk'>
      <driver name='qemu' type='raw' cache='none' io='threads' discard='unmap'/>
      <source file='/var/lib/libvirt/images/win10.img'/>
      <target dev='sda' bus='scsi'/>
      <boot order='1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0x15'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0x16'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0x17'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x7'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0x18'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='10' model='pcie-root-port'>
      <target chassis='10' port='0x19'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
    </controller>
    <controller type='pci' index='11' model='pcie-root-port'>
      <target chassis='11' port='0x1a'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
    </controller>
    <controller type='pci' index='12' model='pcie-root-port'>
      <target chassis='12' port='0x1b'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x3'/>
    </controller>
    <controller type='pci' index='13' model='pcie-root-port'>
      <target chassis='13' port='0x1c'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x4'/>
    </controller>
    <controller type='pci' index='14' model='pcie-root-port'>
      <target chassis='14' port='0x1d'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x5'/>
    </controller>
    <controller type='pci' index='15' model='pcie-root-port'>
      <target chassis='15' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </controller>
    <controller type='pci' index='16' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </controller>
    <controller type='scsi' index='0' model='virtio-scsi'>
      <driver queues='8' iothread='1'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <controller type='sata' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <interface type='network'>
      <mac address='52:54:00:1d:35:91'/>
      <source network='default'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
    </interface>
    <input type='mouse' bus='virtio'>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </input>
    <input type='keyboard' bus='virtio'>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </input>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <graphics type='spice' port='-1' autoport='no'>
      <listen type='address'/>
      <image compression='off'/>
      <gl enable='no'/>
    </graphics>
    <sound model='ich9'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
    </sound>
    <audio id='1' type='pipewire' runtimeDir='/run/user/1000'>
      <input name='qemuinput'/>
      <output name='qemuoutput'/>
    </audio>
    <video>
      <model type='none'/>
    </video>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
    </hostdev>
    <watchdog model='itco' action='reset'/>
    <memballoon model='none'/>
  </devices>
  <qemu:commandline>
    <qemu:arg value='-device'/>
    <qemu:arg value='{&quot;driver&quot;:&quot;ivshmem-plain&quot;,&quot;id&quot;:&quot;shmem0&quot;,&quot;memdev&quot;:&quot;looking-glass&quot;}'/>
    <qemu:arg value='-object'/>
    <qemu:arg value='{&quot;qom-type&quot;:&quot;memory-backend-file&quot;,&quot;id&quot;:&quot;looking-glass&quot;,&quot;mem-path&quot;:&quot;/dev/kvmfr0&quot;,&quot;size&quot;:33554432,&quot;share&quot;:true}'/>
  </qemu:commandline>
</domain>
I’m pretty sure it has something to do with the cgroup_device_acl block. As soon as I uncomment that block, I can no longer start any VMs.
Full /etc/libvirt/qemu.conf
# Master configuration file for the QEMU driver.
# All settings described here are optional - if omitted, sensible
# defaults are used.
# Use of TLS requires that x509 certificates be issued. The default is
# to keep them in /etc/pki/qemu. This directory must contain
#  ca-cert.pem - the CA master certificate
#  server-cert.pem - the server certificate signed with ca-cert.pem
#  server-key.pem  - the server private key
# and optionally may contain
#  dh-params.pem - the DH params configuration file
# If the directory does not exist, libvirtd will fail to start. If the
# directory doesn't contain the necessary files, QEMU domains will fail
# to start if they are configured to use TLS.
# In order to overwrite the default path alter the following. This path
# definition will be used as the default path for other *_tls_x509_cert_dir
# configuration settings if their default path does not exist or is not
# specifically set.
#default_tls_x509_cert_dir = "/etc/pki/qemu"
# The default TLS configuration only uses certificates for the server
# allowing the client to verify the server's identity and establish
# an encrypted channel.
# It is possible to use x509 certificates for authentication too, by
# issuing an x509 certificate to every client who needs to connect.
# Enabling this option will reject any client who does not have a
# certificate signed by the CA in /etc/pki/qemu/ca-cert.pem
# The default_tls_x509_cert_dir directory must also contain
#  client-cert.pem - the client certificate signed with the ca-cert.pem
#  client-key.pem - the client private key
# If this option is supplied it provides the default for the "_verify" option
# of specific TLS users such as vnc, backups, migration, etc. The specific
# users of TLS may override this by setting the specific "_verify" option.
# When not supplied the specific TLS users provide their own defaults.
#default_tls_x509_verify = 1
# Libvirt assumes the server-key.pem file is unencrypted by default.
# To use an encrypted server-key.pem file, the password to decrypt
# the PEM file is required. This can be provided by creating a secret
# object in libvirt and then to uncomment this setting to set the UUID
# of the secret.
# NB This default all-zeros UUID will not work. Replace it with the
# output from the UUID for the TLS secret from a 'virsh secret-list'
# command and then uncomment the entry
#default_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# VNC is configured to listen on 127.0.0.1 by default.
# To make it listen on all public interfaces, uncomment
# this next option.
# NB, strong recommendation to enable TLS + x509 certificate
# verification when allowing public access
#vnc_listen = "0.0.0.0"
# Enable this option to have VNC served over an automatically created
# unix socket. This prevents unprivileged access from users on the
# host machine, though most VNC clients do not support it.
# This will only be enabled for VNC configurations that have listen
# type=address but without any address specified. This setting takes
# preference over vnc_listen.
#vnc_auto_unix_socket = 1
# Enable use of TLS encryption on the VNC server. This requires
# a VNC client which supports the VeNCrypt protocol extension.
# Examples include vinagre, virt-viewer, virt-manager and vencrypt
# itself. UltraVNC, RealVNC, TightVNC do not support this
# It is necessary to setup CA and issue a server certificate
# before enabling this.
#vnc_tls = 1
# In order to override the default TLS certificate location for
# vnc certificates, supply a valid path to the certificate directory.
# If the provided path does not exist, libvirtd will fail to start.
# If the path is not provided, but vnc_tls = 1, then the
# default_tls_x509_cert_dir path will be used.
#vnc_tls_x509_cert_dir = "/etc/pki/libvirt-vnc"
# Uncomment and use the following option to override the default secret
# UUID provided in the default_tls_x509_secret_uuid parameter.
#vnc_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# Enabling this option will reject any client that does not have a
# certificate (as described in default_tls_x509_verify) signed by the
# CA in the vnc_tls_x509_cert_dir (or default_tls_x509_cert_dir).
# If this option is not supplied, it will be set to the value of
# "default_tls_x509_verify". If "default_tls_x509_verify" is not supplied either,
# the default is "0".
#vnc_tls_x509_verify = 1
# The default VNC password. Only 8 bytes are significant for
# VNC passwords. This parameter is only used if the per-domain
# XML config does not already provide a password. To allow
# access without passwords, leave this commented out. An empty
# string will still enable passwords, but be rejected by QEMU,
# effectively preventing any use of VNC. Obviously change this
# example here before you set this.
#vnc_password = "XYZ12345"
# Enable use of SASL encryption on the VNC server. This requires
# a VNC client which supports the SASL protocol extension.
# Examples include vinagre, virt-viewer and virt-manager
# It is necessary to configure /etc/sasl2/qemu.conf to choose
# the desired SASL plugin (eg, GSSPI for Kerberos)
#vnc_sasl = 1
# The default SASL configuration file is located in /etc/sasl2/
# When running libvirtd unprivileged, it may be desirable to
# override the configs in this location. Set this parameter to
# point to the directory, and create a qemu.conf in that location
#vnc_sasl_dir = "/some/directory/sasl2"
# QEMU implements an extension for providing audio over a VNC connection,
# though if your VNC client does not support it, your only chance for getting
# sound output is through regular audio backends. By default, libvirt will
# disable all QEMU sound backends if using VNC, since they can cause
# permissions issues. Enabling this option will make libvirtd honor the
# QEMU_AUDIO_DRV environment variable when using VNC.
#vnc_allow_host_audio = 0
# SPICE is configured to listen on 127.0.0.1 by default.
# this next option.
#spice_listen = "0.0.0.0"
# Enable use of TLS encryption on the SPICE server.
#spice_tls = 1
# spice certificates, supply a valid path to the certificate directory.
# If the path is not provided, but spice_tls = 1, then the
#spice_tls_x509_cert_dir = "/etc/pki/libvirt-spice"
# Enable this option to have SPICE served over an automatically created
# host machine.
# This will only be enabled for SPICE configurations that have listen
# preference over spice_listen.
#spice_auto_unix_socket = 1
# The default SPICE password. This parameter is only used if the
# per-domain XML config does not already provide a password. To
# allow access without passwords, leave this commented out. An
# empty string will still enable passwords, but be rejected by
# QEMU, effectively preventing any use of SPICE. Obviously change
# this example here before you set this.
#spice_password = "XYZ12345"
# Enable use of SASL encryption on the SPICE server. This requires
# a SPICE client which supports the SASL protocol extension.
#spice_sasl = 1
#spice_sasl_dir = "/some/directory/sasl2"
# Enable use of TLS encryption on the chardev TCP transports.
#chardev_tls = 1
# In order to override the default TLS certificate location for character
# device TCP certificates, supply a valid path to the certificate directory.
# If the path is not provided, but chardev_tls = 1, then the
#chardev_tls_x509_cert_dir = "/etc/pki/libvirt-chardev"
# CA in the chardev_tls_x509_cert_dir (or default_tls_x509_cert_dir).
# the default is "1".
#chardev_tls_x509_verify = 1
#chardev_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# Enable use of TLS encryption for all VxHS network block devices that
# don't specifically disable.
# When the VxHS network block device server is set up appropriately,
# x509 certificates are required for authentication between the clients
# (qemu processes) and the remote VxHS server.
# It is necessary to setup CA and issue the client certificate before
# enabling this.
#vxhs_tls = 1
# In order to override the default TLS certificate location for VxHS
# backed storage, supply a valid path to the certificate directory.
# This is used to authenticate the VxHS block device clients to the VxHS
# server.
# If the path is not provided, but vxhs_tls = 1, then the
# VxHS block device clients expect the client certificate and key to be
# present in the certificate directory along with the CA master certificate.
# If using the default environment, default_tls_x509_verify must be configured.
# Since this is only a client the server-key.pem certificate is not needed.
# Thus a VxHS directory must contain the following:
#vxhs_tls_x509_cert_dir = "/etc/pki/libvirt-vxhs"
#vxhs_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# Enable use of TLS encryption for all NBD disk devices that don't
# specifically disable it.
# When the NBD server is set up appropriately, x509 certificates are required
# for authentication between the client and the remote NBD server.
# enabling this.
#nbd_tls = 1
# In order to override the default TLS certificate location for NBD
# This is used to authenticate the NBD block device clients to the NBD
# server.
# If the path is not provided, but nbd_tls = 1, then the
# NBD block device clients expect the client certificate and key to be
# present in the certificate directory along with the CA certificate.
# Thus a NBD directory must contain the following:
#nbd_tls_x509_cert_dir = "/etc/pki/libvirt-nbd"
#nbd_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# In order to override the default TLS certificate location for migration
# certificates, supply a valid path to the certificate directory. If the
# provided path does not exist, libvirtd will fail to start. If the path is
# not provided, but TLS-encrypted migration is requested, then the
# default_tls_x509_cert_dir path will be used. Once/if a default certificate is
# enabled/defined, migration will then be able to use the certificate via
# migration API flags.
#migrate_tls_x509_cert_dir = "/etc/pki/libvirt-migrate"
# CA in the migrate_tls_x509_cert_dir (or default_tls_x509_cert_dir).
# either, the default is "1".
#migrate_tls_x509_verify = 1
#migrate_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# By default TLS is requested using the VIR_MIGRATE_TLS flag, thus not requested
# automatically. Setting 'migate_tls_force' to "1" will prevent any migration
# which is not using VIR_MIGRATE_TLS to ensure higher level of security in
# deployments with TLS.
#migrate_tls_force = 0
# In order to override the default TLS certificate location for backup NBD
# server certificates, supply a valid path to the certificate directory. If the
# not provided, but TLS-encrypted backup is requested, then the
#backup_tls_x509_cert_dir = "/etc/pki/libvirt-backup"
# CA in the backup_tls_x509_cert_dir (or default_tls_x509_cert_dir).
#backup_tls_x509_verify = 1
#backup_tls_x509_secret_uuid = "00000000-0000-0000-0000-000000000000"
# By default, if no graphical front end is configured, libvirt will disable
# QEMU audio output since directly talking to alsa/pulseaudio may not work
# with various security settings. If you know what you're doing, enable
# the setting below and libvirt will passthrough the QEMU_AUDIO_DRV
# environment variable when using nographics.
#nographics_allow_host_audio = 1
# Override the port for creating both VNC and SPICE sessions (min).
# This defaults to 5900 and increases for consecutive sessions
# or when ports are occupied, until it hits the maximum.
# Minimum must be greater than or equal to 5900 as lower number would
# result into negative vnc display number.
# Maximum must be less than 65536, because higher numbers do not make
# sense as a port number.
#remote_display_port_min = 5900
#remote_display_port_max = 65535
# VNC WebSocket port policies, same rules apply as with remote display
# ports.  VNC WebSockets use similar display <-> port mappings, with
# the exception being that ports start from 5700 instead of 5900.
#remote_websocket_port_min = 5700
#remote_websocket_port_max = 65535
# The default security driver is SELinux. If SELinux is disabled
# on the host, then the security driver will automatically disable
# itself. If you wish to disable QEMU SELinux security driver while
# leaving SELinux enabled for the host in general, then set this
# to 'none' instead. It's also possible to use more than one security
# driver at the same time, for this use a list of names separated by
# comma and delimited by square brackets. For example:
#       security_driver = [ "selinux", "apparmor" ]
# Notes: The DAC security driver is always enabled; as a result, the
# value of security_driver cannot contain "dac".  The value "none" is
# a special value; security_driver can be set to that value in
# isolation, but it cannot appear in a list of drivers.
#security_driver = "selinux"
# If set to non-zero, then the default security labeling
# will make guests confined. If set to zero, then guests
# will be unconfined by default. Defaults to 1.
#security_default_confined = 1
# If set to non-zero, then attempts to create unconfined
# guests will be blocked. Defaults to 0.
#security_require_confined = 1
# The user for QEMU processes run by the system instance. It can be
# specified as a user name or as a user id. The qemu driver will try to
# parse this value first as a name and then, if the name doesn't exist,
# as a user id.
# Since a sequence of digits is a valid user name, a leading plus sign
# can be used to ensure that a user id will not be interpreted as a user
# name.
# Some examples of valid values are:
#       user = "qemu"   # A user named "qemu"
#       user = "+0"     # Super user (uid=0)
#       user = "100"    # A user named "100" or a user with uid=100
user = "ian"
# The group for QEMU processes run by the system instance. It can be
# specified in a similar way to user.
#group = "libvirt-qemu"
# Whether libvirt should dynamically change file ownership
# to match the configured user/group above. Defaults to 1.
# Set to 0 to disable file ownership changes.
#dynamic_ownership = 1
# Whether libvirt should remember and restore the original
# ownership over files it is relabeling. Defaults to 1, set
# to 0 to disable the feature.
#remember_owner = 1
# What cgroup controllers to make use of with QEMU guests
#  - 'cpu' - use for scheduler tunables
#  - 'devices' - use for device access control
#  - 'memory' - use for memory tunables
#  - 'blkio' - use for block devices I/O tunables
#  - 'cpuset' - use for CPUs and memory nodes
#  - 'cpuacct' - use for CPUs statistics.
# NB, even if configured here, they won't be used unless
# the administrator has mounted cgroups, e.g.:
#  mkdir /dev/cgroup
#  mount -t cgroup -o devices,cpu,memory,blkio,cpuset none /dev/cgroup
# They can be mounted anywhere, and different controllers
# can be mounted in different locations. libvirt will detect
# where they are located.
#cgroup_controllers = [ "cpu", "devices", "memory", "blkio", "cpuset", "cpuacct" ]
# This is the basic set of devices allowed / required by
# all virtual machines.
# As well as this, any configured block backed disks,
# all sound device, and all PTY devices are allowed.
# This will only need setting if newer QEMU suddenly
# wants some device we don't already know about.
cgroup_device_acl = [
    "/dev/null", "/dev/full", "/dev/zero",
    "/dev/random", "/dev/urandom",
    "/dev/ptmx", "/dev/kvm",
    "/dev/userfaultfd"
    "/dev/kvmfr0"
# RDMA migration requires the following extra files to be added to the list:
#   "/dev/infiniband/rdma_cm",
#   "/dev/infiniband/issm0",
#   "/dev/infiniband/issm1",
#   "/dev/infiniband/umad0",
#   "/dev/infiniband/umad1",
#   "/dev/infiniband/uverbs0"
# The default format for QEMU/KVM guest save images is raw; that is, the
# memory from the domain is dumped out directly to a file.  If you have
# guests with a large amount of memory, however, this can take up quite
# a bit of space.  If you would like to compress the images while they
# are being saved to disk, you can also set "zstd", "lzop", "gzip", "bzip2",
# or "xz" for save_image_format. Note that this means you slow down the process
# of saving a domain in order to save disk space.
# save_image_format is used when you use 'virsh save' or 'virsh managedsave'
# at scheduled saving, and it is an error if the specified save_image_format
# is not valid, or the requested compression program can't be found.
# dump_image_format is used when you use 'virsh dump' at emergency
# crashdump, and if the specified dump_image_format is not valid, or
# the requested compression program can't be found, this falls
# back to "raw" compression.
# snapshot_image_format specifies the compression algorithm of the memory save
# image when an external snapshot of a domain is taken. This does not apply
# on disk image format. It is an error if the specified format isn't valid,
# or the requested compression program can't be found.
#save_image_format = "raw"
#dump_image_format = "raw"
#snapshot_image_format = "raw"
# When a domain is configured to be auto-dumped when libvirtd receives a
# watchdog event from qemu guest, libvirtd will save dump files in directory
# specified by auto_dump_path. Default value is /var/lib/libvirt/qemu/dump
#auto_dump_path = "/var/lib/libvirt/qemu/dump"
# When a domain is configured to be auto-dumped, enabling this flag
# has the same effect as using the VIR_DUMP_BYPASS_CACHE flag with the
# virDomainCoreDump API.  That is, the system will avoid using the
# file system cache while writing the dump file, but may cause
# slower operation.
#auto_dump_bypass_cache = 0
# When a domain is configured to be auto-started, enabling this flag
# has the same effect as using the VIR_DOMAIN_START_BYPASS_CACHE flag
# with the virDomainCreateWithFlags API.  That is, the system will
# avoid using the file system cache when restoring any managed state
# file, but may cause slower operation.
#auto_start_bypass_cache = 0
# If provided by the host and a hugetlbfs mount point is configured,
# a guest may request huge page backing.  When this mount point is
# unspecified here, determination of a host mount point in /proc/mounts
# will be attempted.  Specifying an explicit mount overrides detection
# of the same in /proc/mounts.  Setting the mount point to "" will
# disable guest hugepage backing. If desired, multiple mount points can
# be specified at once, separated by comma and enclosed in square
# brackets, for example:
#     hugetlbfs_mount = ["/dev/hugepages2M", "/dev/hugepages1G"]
# The size of huge page served by specific mount point is determined by
# libvirt at the daemon startup.
# NB, within these mount points, guests will create memory backing
# files in a location of $MOUNTPOINT/libvirt/qemu
#hugetlbfs_mount = "/dev/hugepages"
# Path to the setuid helper for creating tap devices.  This executable
# is used to create <source type='bridge'> interfaces when libvirtd is
# running unprivileged.  libvirt invokes the helper directly, instead
# of using "-netdev bridge", for security reasons.
# If this is not an absolute path, the program will be searched for
# in $PATH as well as a few additional directories.
#bridge_helper = "qemu-bridge-helper"
# If enabled, libvirt will have QEMU set its process name to
# "qemu:VM_NAME", where VM_NAME is the name of the VM. The QEMU
# process will appear as "qemu:VM_NAME" in process listings and
# other system monitoring tools. By default, QEMU does not set
# its process title, so the complete QEMU command (emulator and
# its arguments) appear in process listings.
#set_process_name = 1
# If max_processes is set to a positive integer, libvirt will use
# it to set the maximum number of processes that can be run by qemu
# user. This can be used to override default value set by host OS.
# The same applies to max_files which sets the limit on the maximum
# number of opened files.
#max_processes = 0
#max_files = 0
# If max_threads_per_process is set to a positive integer, libvirt
# will use it to set the maximum number of threads that can be
# created by a qemu process. Some VM configurations can result in
# qemu processes with tens of thousands of threads. systemd-based
# systems typically limit the number of threads per process to
# 16k. max_threads_per_process can be used to override default
# limits in the host OS.
#max_threads_per_process = 0
# If max_core is set to a non-zero integer, then QEMU will be
# permitted to create core dumps when it crashes, provided its
# RAM size is smaller than the limit set.
# Be warned that the core dump will include a full copy of the
# guest RAM, if the 'dump_guest_core' setting has been enabled,
# or if the guest XML contains
#   <memory dumpCore="on">...guest ram...</memory>
# If guest RAM is to be included, ensure the max_core limit
# is set to at least the size of the largest expected guest
# plus another 1GB for any QEMU host side memory mappings.
# As a special case it can be set to the string "unlimited" to
# to allow arbitrarily sized core dumps.
# By default the core dump size is set to 0 disabling all dumps
# Size is a positive integer specifying bytes or the
# string "unlimited"
#max_core = "unlimited"
# Determine if guest RAM is included in QEMU core dumps. By
# default guest RAM will be excluded if a new enough QEMU is
# present and host kernel supports it. Setting this to '1' will
# force guest RAM to always be included in QEMU core dumps.
# This setting will be ignored if the guest XML has set the
# dumpCore attribute on the <memory> element.
#dump_guest_core = 1
# mac_filter enables MAC addressed based filtering on bridge ports.
# This currently requires ebtables to be installed.
#mac_filter = 1
# By default, PCI devices below non-ACS switch are not allowed to be assigned
# to guests. By setting relaxed_acs_check to 1 such devices will be allowed to
# be assigned to guests.
#relaxed_acs_check = 1
# In order to prevent accidentally starting two domains that
# share one writable disk, libvirt offers two approaches for
# locking files. The first one is sanlock, the other one,
# virtlockd, is then our own implementation. Accepted values
# are "sanlock" and "lockd".
#lock_manager = "lockd"
# Set limit of maximum APIs queued on one domain. All other APIs
# over this threshold will fail on acquiring job lock. Specially,
# setting to zero turns this feature off.
# Note, that job lock is per domain.
#max_queued = 0
# Keepalive protocol:
# This allows qemu driver to detect broken connections to remote
# libvirtd during peer-to-peer migration.  A keepalive message is
# sent to the daemon after keepalive_interval seconds of inactivity
# to check if the daemon is still responding; keepalive_count is a
# maximum number of keepalive messages that are allowed to be sent
# to the daemon without getting any response before the connection
# is considered broken.  In other words, the connection is
# automatically closed approximately after
# keepalive_interval * (keepalive_count + 1) seconds since the last
# message received from the daemon.  If keepalive_interval is set to
# -1, qemu driver will not send keepalive requests during
# peer-to-peer migration; however, the remote libvirtd can still
# send them and source libvirtd will send responses.  When
# keepalive_count is set to 0, connections will be automatically
# closed after keepalive_interval seconds of inactivity without
# sending any keepalive messages.
#keepalive_interval = 5
#keepalive_count = 5
# Use seccomp syscall filtering sandbox in QEMU.
# 1 == filter enabled, 0 == filter disabled
# Unless this option is disabled, QEMU will be run with
# a seccomp filter that stops it from executing certain
# syscalls.
#seccomp_sandbox = 1
# Override the listen address for all incoming migrations. Defaults to
# 0.0.0.0, or :: if both host and qemu are capable of IPv6.
#migration_address = "0.0.0.0"
# The default hostname or IP address which will be used by a migration
# source for transferring migration data to this host.  The migration
# source has to be able to resolve this hostname and connect to it so
# setting "localhost" will not work.  By default, the host's configured
# hostname is used.
#migration_host = "host.example.com"
# Override the port range used for incoming migrations.
# Minimum must be greater than 0, however when QEMU is not running as root,
# setting the minimum to be lower than 1024 will not work.
# Maximum must not be greater than 65535.
#migration_port_min = 49152
#migration_port_max = 49215
# Timestamp QEMU's log messages (if QEMU supports it)
# Defaults to 1.
#log_timestamp = 0
# Location of master nvram file
# This configuration option is obsolete. Libvirt will follow the
# QEMU firmware metadata specification to automatically locate
# firmware images. See docs/interop/firmware.json in the QEMU
# source tree. These metadata files are distributed alongside any
# firmware images intended for use with QEMU.
# NOTE: if ANY firmware metadata files are detected, this setting
# will be COMPLETELY IGNORED.
# When a domain is configured to use UEFI instead of standard
# BIOS it may use a separate storage for UEFI variables. If
# that's the case libvirt creates the variable store per domain
# using this master file as image. Each UEFI firmware can,
# however, have different variables store. Therefore the nvram is
# a list of strings when a single item is in form of:
#   ${PATH_TO_UEFI_FW}:${PATH_TO_UEFI_VARS}.
# Later, when libvirt creates per domain variable store, this list is
# searched for the master image. The UEFI firmware can be called
# differently for different guest architectures. For instance, it's OVMF
# for x86_64 and i686, but it's AAVMF for aarch64. The libvirt default
# follows this scheme.
#nvram = [
#   "/usr/share/OVMF/OVMF_CODE.fd:/usr/share/OVMF/OVMF_VARS.fd",
#   "/usr/share/OVMF/OVMF_CODE.secboot.fd:/usr/share/OVMF/OVMF_VARS.fd",
#   "/usr/share/AAVMF/AAVMF_CODE.fd:/usr/share/AAVMF/AAVMF_VARS.fd",
#   "/usr/share/AAVMF/AAVMF32_CODE.fd:/usr/share/AAVMF/AAVMF32_VARS.fd"
# The backend to use for handling stdout/stderr output from
# QEMU processes.
#  'file': QEMU writes directly to a plain file. This is the
#          historical default, but allows QEMU to inflict a
#          denial of service attack on the host by exhausting
#          filesystem space
#  'logd': QEMU writes to a pipe provided by virtlogd daemon.
#          This is the current default, providing protection
#          against denial of service by performing log file
#          rollover when a size limit is hit.
#stdio_handler = "logd"
# QEMU gluster libgfapi log level, debug levels are 0-9, with 9 being the
# most verbose, and 0 representing no debugging output.
# The current logging levels defined in the gluster GFAPI are:
#    0 - None
#    1 - Emergency
#    2 - Alert
#    3 - Critical
#    4 - Error
#    5 - Warning
#    6 - Notice
#    7 - Info
#    8 - Debug
#    9 - Trace
# Defaults to 4
#gluster_debug_level = 9
# virtiofsd debug
# Whether to enable the debugging output of the virtiofsd daemon.
# Possible values are 0 or 1. Disabled by default.
#virtiofsd_debug = 1
# To enhance security, QEMU driver is capable of creating private namespaces
# for each domain started. Well, so far only "mount" namespace is supported. If
# enabled it means qemu process is unable to see all the devices on the system,
# only those configured for the domain in question. Libvirt then manages
# devices entries throughout the domain lifetime. This namespace is turned on
# by default.
#namespaces = [ "mount" ]
# This directory is used for memoryBacking source if configured as file.
# NOTE: big files will be stored here
#memory_backing_dir = "/var/lib/libvirt/qemu/ram"
# Path to the SCSI persistent reservations helper. This helper is
# used whenever <reservations/> are enabled for SCSI LUN devices.
#pr_helper = "qemu-pr-helper"
# Path to the SLIRP networking helper.
#slirp_helper = "/usr/bin/slirp-helper"
# Path to the dbus-daemon
# in $PATH.
#dbus_daemon = "dbus-daemon"
# User for the swtpm TPM Emulator
# Default is 'tss'; this is the same user that tcsd (TrouSerS) installs
# and uses; alternative is 'root'
#swtpm_user = "tss"
#swtpm_group = "tss"
# For debugging and testing purposes it's sometimes useful to be able to disable
# libvirt behaviour based on the capabilities of the qemu process. This option
# allows to do so. DO _NOT_ use in production and beaware that the behaviour
# may change across versions.
#capability_filters = [ "capname" ]
# 'deprecation_behavior' setting controls how the qemu process behaves towards
# deprecated commands and arguments used by libvirt.
# This setting is meant for developers and CI efforts to make it obvious when
# libvirt relies on fields which are deprecated so that it can be fixes as soon
# as possible.
# Possible options are:
# "none"   - (default) qemu is supposed to accept and output deprecated fields
#            and commands
# "omit"   - qemu is instructed to omit deprecated fields on output, behaviour
#            towards fields and commands from qemu is not changed
# "reject" - qemu is instructed to report an error if a deprecated command or
#            field is used by libvirtd
# "crash"  - qemu crashes when an deprecated command or field is used by libvirtd
# For both "reject" and "crash" qemu is instructed to omit any deprecated fields
# on output.
# The "reject" option is less harsh towards the VMs but some code paths ignore
# errors reported by qemu and thus it may not be obvious that a deprecated
# command/field was used, thus it's suggested to use the "crash" option instead.
# In cases when qemu doesn't support configuring the behaviour this setting is
# silently ignored to allow testing older qemu versions without having to
# reconfigure libvirtd.
# DO NOT use in production.
#deprecation_behavior = "none"
# If this is set then QEMU and its threads will run in a separate scheduling
# group meaning no other process will share Hyper Threads of a single core with
# QEMU. Each QEMU has its own group.
# "none"     - (default) neither QEMU or any of its helper processes are placed
#              into separate scheduling group
# "vcpus"    - only QEMU vCPU threads are placed into a separate scheduling group,
#              emulator threads and helper processes remain outside of the group
# "emulator" - only QEMU and its threads (emulator + vCPUs) are placed into
#              separate scheduling group, helper processes remain outside of
#              the group
# "full"    -  both QEMU and its helper processes are placed into separate
#              scheduling group
#sched_core = "none"
# Using nbdkit to access remote disk sources
# If this is set then libvirt will use nbdkit to access remote disk sources
# when available. nbdkit will export an NBD share to QEMU rather than having
# QEMU attempt to access the remote server directly.
# Possible values are 0 or 1. Default value is 1. Please
# note that the default might change in future releases.
#storage_use_nbdkit = 1
Commenting out this block and running systemctl restart libvirtd.service allows for VMs to be started again.
Any ideas what might be the culprit?
You’re missing a comma after /dev/userfaultfd. Change:
    "/dev/userfaultfd"
    "/dev/kvmfr0"
To:
    "/dev/userfaultfd",
    "/dev/kvmfr0"
You gotta be kidding me. :smiley:
I knew it would be something trivial, but damn, a comma. This is embarrassing. :smiley:
Just tried it and while the framerate didn’t improve, it does feel less sluggish now.
Thank you for your help!!
