I'm not exactly sure what happened, but I sat down to use my laptop and it took forever for it to "wakeup" then the GUI login wouldn't work, and I had to do ctrl-alt-F2 to login. Here's an example error message when I tried to to "sudo reboot"
"Command sudo is available in usr'bin/sudo".
To check my environment variable I had to type,
"usr/bin/sudo /usr/bin/nano /etc/environment"
Nothing seems out of place in environment, what I have is
This setup has been working for several weeks no problem. The last thing I remember doing configuration wise is that I installed IntelliJ IDEA, but I didn't do anything with environment, all I did was install it.
So right now I can't get to the regular desktop, and I have to type out the path to everything. Even "ls" doesn't work, or "cd.."
Untaring into /usr is dangerous, but lets fix the problem we can see first ;)
Modify /etc/enviroment to this (remove the export bits):
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/games"
JAVA_HOME="/usr/lib/jvm/java-7-oracle/jre/bin/java"
PATH=$PATH:/usr/lib/jvm/java-7-oracle/jre/bin/java (or just remove this line)
please add 4 spaces or enclose use the </> button so we know the forum isn't mangling your pastes
export is a command so youd use it in a shell or script, but not in files that store data. Quite how it does what you saw i'd need to work out, but glad its fixed
