I’m trying to get my VM working but I hit a snag. I’m able to get my video output via the 1080Ti but its stuck on a resolution of 800 x 600 and as the video card it says windows standard video output. I just thought that it was a driver issue but was able to install the drivers without any problems. But the problem persisted. Then I made my windows partition into a virtual partition and used that to boot the VM with, knowing for sure the drivers worked. But I’m still having the same issue. Any guesses to why?
System specs: Fedora 27, virtmanager as the virtualizer. Ryzen 1800X AMD R460 as primary gpu and a 1080Ti as secondary.
This is the error Nvidia Drivers throw when they see they’re in a Hypervisor (Virtualized). You need to trick them into thinking they’re running on a normal machine.
I’m having the same issue with a GT 710.
See my thread for things I’ve tried (One of them may work for you, knowing my luck):
For you, it could be as simple as adding hv_vendor_id=null to your KVM configuration.
I have a solution about boot GPU.
with this solution,you can remove your primary card.
and set bios output > pcie slot 1.
yeah gtx 1080ti shows bios and linux booting and vm booting and running normally
Hi i am very new Linux User since 4 days. I had the same problem. By default, some Nvidia drivers will actually disable your graphics card if it appears to be running in a VM.
Thank you for reply.
3 reasons:
because many motherboards (i have a H110M) do not have 2 or more PCIE x16/x8/x4 slot.
when you have 2 PCIE x16 slots and want to launch 2 Gaming VMs(maybe 2 gtx1080), there is no slot for the weak primary card.
if I want to buy a Gaming PC,I will not buy a weak primary card additionally.
