Ok so I have been using sony vegas for a while now and I am having a huge issue. Vegas last night kept crashing when I tried to edit a video about an hour long (only wanted to render half becuase it was two episodes worth or recordings) and I had to restart the program 20+ times within the 1-1.5 hour editing span of the video. There is an intro, outro, two audio and two video tracks, and one of the tracks has chroma keying on it as well as cookie cutter and shrink applied (the facecam). It also crashed many times while rendering at about 60% but there is nothing special at that time so idk what it mmight be. I also render them in 1920x1080 60fps (59.94) as they were recorded. I have a 4790k, 980Ti Zotac Reference, 32g of 1600 Corsair vengance RAM, plz help!!
Crash log is as follows:
Extra Information
File: C:\Users\Alden Stidom\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
File: C:\Users\Alden Stidom\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
File: C:\Users\Alden Stidom\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
File: C:\Users\Alden Stidom\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
File: C:\Users\Alden Stidom\AppData\Local\Sony\Vegas Pro\13.0\gpu_video_x64.log
File: Y:\Editing In Progress\Life is Strange Episodes 3&4\Episode 3-4 Project.veg
Problem Description
Application Name: Vegas Pro
Application Version: Version 13.0 (Build 290) 64-bit
Problem: Unmanaged Exception (0xc0000005)
Fault Module: C:\WINDOWS\SYSTEM32\ntdll.dll
Fault Address: 0x00007FFEB8D4D85E
Fault Offset: 0x000000000003D85E
Fault Process Details
Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
Process Version: Version 13.0 (Build 290) 64-bit
Process Description: Vegas Pro
Process Image Date: 2014-04-10 (Thu Apr 10) 14:27:08
The Fault module is the same in every crash instance and OS is win 8.1.
