Can two evga 780Ti classified's fit in the Silverstone FT03 case? If not will the superclocked or the reference cards fit? Also can I get an H80i to fit in the top 120mm fan bracket? Thanks!
I you can fit the H80i. The Gtx 780 ti's are going to be kinda close. I'd recommend the reference card just so your not putting huge amounts of warm air into that tiny case. The build I found had Sli Gtx 660's and those are 1 inch shorter than the Gtx 780 ti. It looked like he had a goo amount of room... Here's the build http://pcpartpicker.com/b/KBx Also JayzTwoCents put out a build in this case here: https://www.youtube.com/watch?v=WJlr_0ingWY he had a reference Gtx 780 which is the exact same as the 780 ti reference in length.
Thanks for the info! I now see the H80i fits with no problem, but in that build from pcpartpicker I am just not seeing an extra 1 inch of room for the 780Ti. I tried to see if in the video if a second 780 would fit but I just couldn't find a good angle.
I found this: http://cdn.overclock.net/4/4c/900x900px-LL-4c1d6437_FT03Titan.jpeg So I am thinking that 2 780Ti's will not fit with a 120mm fan! Also does anyone know of some nice 80mm fans?
i had an h80i in mine as well as 780s in sli (reference design coolers) they dident jump above 77c when playing most games. it was a loud system though. also its worth noting that the h80i can have issues with some matx mobos my vi gene could only accept it one way so before you buy anything i would recommend you look around on the ft03 owners club and see if anyone's using the same set of parts you are (im gaguya there as well and you can see my system in pictures to see how close of a fit things are.)
