my question
i have a 2.5" HDD 320GB and it writes very slow. when i am level 30 in Minecraft i make a bunch of copies of my save (normally 20) and it takes a few minutes to make these copies. this is so i can select a good enchantment.
what i want to do is re-direct the %appdata%/.minecraft to the ramdisk so these copies are much faster. and then when i back up the saves to their normal place.
my system
AMD FX8350, Zalman CNPS 10x Quiet, Asus M5A99FX Pro R2, HD 7870 (@1050), 8GB DDR1333 (2x4GB Dual channel), cheap 2.5" 5200RPM 320GB HDD, Corsair 600w, Zalman Z9 Plus.
i also have the AMD RamDisk software installed with it set up for a 2.5GB, which is more than enough for my current Minecraft save (currently 91MB) copied 20 times.
