[SOLVED] PSU Recommendation
I've got the other parts set but I'm just not sure where to go with a PSU.
I know I need at least 80+ bronze but I'm not sure about wattage.
Hardware:
MoBo: ASUS Z87-A
CPU: i7-4771
RAM: Corsair Vengeance 2x4GB 1600MHz
(Not too sure that storage makes a difference but I'll list it anyway)
SSD: Samsung 840 120GB
HDD: Seagate Barracuda 1TB (x2)
GFX: ASUS GTX 780-DC2OC-3GD5
SOLVED: I picked the Seasonic S12G-550 recommended by: Ksajal
I'll guess you need 100 W for the CPU max sustained (probably a conservative number), and 250 W max sustained for the GPU.  That's 350 W total needed, max actual sustained use, on the 12 V rail.  What you use in reality, running a game for example, will probably be lower than that.
The $30 Corsair CX430 promises 12 X 32 = 384 W on the 12 V rail.  If you believe the PSU can deliver its rated power, and you can keep that PSU cool under duress -- it's rated at a pretty low temperature -- then it will work.
If you don't like living on the edge, then you can do what most people do, which is A) get a PSU with a higher rating, or B) get a PSU with a design that makes all power available on 12 V.  Or both, of course.
What most people do is over-engineer the system a little bit, and choose a power rating that puts your power needs (350 W) at 50% to 75% the rated capacity.  This usually puts the PSU in its efficient zone, reducing heat, and also makes it more likely your system can operate in a cool calm and collected manner no matter what.
What Dell does, is to "optimize" the PSU and designs the system cooling so it can do what it needs to and not a GHz more.
You can go either way and there is no single answer to how much wattage you need.
Corsair RM550 is a very decent psu, more then enough for your needs, there is also an RM450 if im right. THey are not the cheapest but they are decent.
There is but if his needs are 350 W, 350 / 0.75 is 467 W, so I'm curious how you arrive at your suggestion.
I'm not saying your suggestion is wrong, I think it would help to see your method.  Maybe it's better than mine.
As for the RM550 I think the Seasonic G 550 is cheaper and is at least as good as the RM.
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_780_Ti/25.html
peak power draw of the gpu is going to be 269 watts.
seasonic G550 would be the best option I think at about $80  80+gold and modular
http://www.amazon.com/SeaSonic-550-Watt-CrossFire-Certified-SSR-550RM/dp/B00918MEZG/ref=sr_1_2?ie=UTF8&qid=1389746938&sr=8-2&keywords=seasonic+power+supply
I actually recommend the Seasonic SG550, same unit as the G550, but it's not modular, and because of that, cheaper than the G550. And also a bit shorter, if that's what you are looking for.
@Reservation Station: people prefer their PSU to be used at 50% - 75% of its rated capacity. Let's call that Y. The hardware will draw about 350W. For the PSU to function at 50% capacity you would need a capacity of: 0.5*Y=350, Y=350/0.5=700W.  For the PSU to function at 75% capacity you would need Y=467W. Therefore the PSU needs to have a maximum capacity somewhere in between 467 and 700W.
EDIT: I've just realized I got the name wrong, it's Seasonic S12G-550. Here: http://seasonic.com/pdf/datasheet/NEW/Retail/S12G-450-550-650-750.pdf
You said it clearer than I could! :)
well i mostly recommend a 550W psu for a single gpu setup, should be more then enough. its allways good to have some headroom. corsair, seasonic XFX are all decent psu´s. i can come up with a complete math, but i dont realy see the value of that ☺
I agree with MisteryAngel, 550W is more than enough for one graphics card. Unless you have one of those crazy insane GPUs which have two 8-pin connectors and one 6 pin, that's 450W power draw (EVGA Kingpin) .
A PSU should be ideally specked for maximum continuous running at about 80% usage, this not only helps it keep cool, run efficiently and last a long time but it also takes into consideration that spike loading may (will in the real world) exceed the normal current draw of a device. It also gives headroom should you overclock or upgrade something (CPU or GPU) in future, not to mention some of the other gadgets in the system such as DVD writers or a charging phone or tablet on a USB port. So for a 350w to be 80%, we'd need a 437.5watt supply. As for the seasonic, if you can get one with basic specs like modular cables, a decent fan and bronze rating then go ahead, its a good brand, but the RM is also a good supply, so I doubt you'll see a difference. I would however avoid Corsairs CX series, its built very cheap and can cause issues as a result, although really it'll still do the job, just remember regardless of what you buy your are risking frying everything hats currently hooked up (even devices on charge or portable storage that's plugged in) should it fail.
Peak efficiency is between 50 and 70% load, this is true, but according to 80+ spec, the efficiency should be at least the minimum for each level at 20, 50, and 100% loads, so there the somewhat nominal difference in efficiency between an 80-90% loaded PSU and a 50-70% loaded PSU isn't really worth considering.
The G550 is a fantastic unit, yes, with low ripple, high efficiency, great build quality, and decent connectivity - well worth it if you can find it for ~$80 (or less). The RM550 is a Seasonic OEM, if I recall, as with most of the RM series, so any price markup isn't worth paying, since, internally, they are very similar.
I personally have the RM550, 80 plus gold, along with fully modular and flat cables make it a really nice PSU, also the fact that it doesn't turn the fan on until your at 40% load makes it really quiet too. I can vouch for the RM550.
I think I'll go with this one (S12G-550), I'll be overclocking slightly (slightly) so a bit of headroom is nice.
Thanks.
