[solved] Problems Booting Up
Hi, I hope there is someone here who can help me. I am just in the process of building my new PC and have ran into a problem.I have a Gigabyte Z87X-OC with an 4770k and the PSU is Antec High Current Gamer 750W Modular.
When I power up the PC it starts, the CPU fan is running, but after 10-15 seconds it shuts down and restarts and this keeps happening on a loop. There is an error code on the motherboard is 15 which is pre memory north bridge is starting, according to the manual. I've tried removing every component but no matter what I do the LED code stays the same.
Many thanks Darrell
hmm i would suggest to take everything out of the case, lay the motherboard on its box, install the cpu and cpu cooler, 1 stick of ram and connect the psu, 24 pin ATX connector and 8 pin cpu power connector. connect the monitor to the onboard video port from the monitor and fire it up outside the case, if there is no power button on the board it self, then checkout the manual and short the power switch pins for a second with a screw driver or paperclip, and look if its working then. could be a screw or something that causing a short cirquit.
It works it works at last i have got it working.
I took your advise and took it out of the case and it just powered up and it working great, I cannot thank you enough, sometimes you are so into a build you cannot see the the most simple problems.
Keep up the good work and again many thanks Darrell
Thats great news. Have fun with your build ☺
