[SOLVED] Pop!_OS; Is there any Virtual Audio Cables out there?
Hey!
I just set up my audio for OBS Studio, and it’s a lot better then it was before, BUT I want those settings to be system wide, in Windows I used a Virtual Audio Cable and VoiceMeeter Banana, for the audio of Discord, and other applications, that I no longer use. I want to have that crisp audio in Discord too, so I’m looking for a GNU/Linux alternative, and since I’m not using KDE/Plasma, (Since it’s superior it might have some audio setup fixes that makes it possible to add such things from the box, dunno, haven’t tested it before though… "/ ) I might not be able to fix this in GNOME/Cosmic without a plugin or application, but my search has not given me any true options.
Do any of you have any tips & hackz? ;D
Watching this now, going to see if it’s solved or not later on.
