I had my server on dhcp dynamic address on my pfsense router. Well now it has changed and I have a ton of ports to an address that I cannot switch my server to.
Pfsense complains that the address …100.10 is out of range
The range is …100.1-…100.110
Do I need to restart my pfsense router?
Edit: Restarted my router. Still nothing. Changed from …100.100 to …100.2
Solved:
Following errors:
The ip address must not be in the dhcp range for this interface
I had to change the range from …100.1 to …100.11
Please clarify. your DHCP range is xxx.xxx.100.1 through xxx.xxx.100.110 and you are attempting to manually configure an address on your server, which is within the DHCP range?
You can go into Status/DHCP Leases and add a static mapping for your server.
