My old PC started shutting down (it’s like some unplugged it from the wall) at semi random times and then it tries to start up again but it can’t. It just loops without getting event to the boot screen until i unplug it from the wall, then it can start up normally. This happens at semi random times. Sometimes when i’m browsing the web, watching a movie or just typing. Weird thing is some games cause it to shut down immediately (like rocket league), but when i run synthetic tests for cpu and gpu (furmark, prime95) at the same time it doesn’t shut down. I’ve also noticed that it much more stable under linux, i rarely experience any shutdowns. My first thought was the PSU but if it was the problem the pc should shut down under synthetic test. Any thoughts?
Gigabyte EP43-UD3L
Q9550 @3.4Ghz
Geil 8Gb DDR2
Radeon 6950
Samsung 840 EVO
Random HDD
Seasonic G-550
I’ve tried stressing the memory with prime95 and the system ran fine. Also cpu temperatures are normal and i haven’t seen any bulged capacitors on the motherboard. SMART status is also ok.
Is it possible that the psu is at fault? But then why would it not start normal and i have to unplug it from the wall to get a normal boot.
Sure, anything is possible as long as you don’t rule it out by testing with replacement hardware.
Prime is a CPU test mostly, you could run a memtest86 USB stick over night and look what happens.
And really, try a different drive with a fresh install.
It looks like it was a faulty PSU. Tried mine in another pc, worked with no problems for a day and then the motherboard started throwing anti surge protection warnings. Also put another PSU in my pc and it worked with no problems.
