[SOLVED] NVME drives failing in x570 system
Two sets of NVME ssd’s would work initially after being installed in an x570 Crosshair VIII motherboard but would begin failing in very strange ways after hours to a day later.
Solution:
It appears all my problems have been solved by buying an asus hyper m.2 AIC. To get it working properly I had to set the operating mode of PCIEx16_2 to raid (even though the drives themselves aren’t configured for raid operation).
This solution allows me to run a GPU in PCIEx16_1 and PCIEx16_3 with the two ssd’s connected to the second slot via the hyper m.2 NVME adapter board, installed in slots m.2_1 and m.2_2 (m.2_1 and m.2_3 is an invalid configuration).
I do not know if other x570 motherboards will produce the same issues with similar dual GPU and dual NVME installs making use of all available on-board m.2 slots but the only way for me to get these disks working was to install them in such a way that they were alloted exclusive use of the x8 lanes of the second PCIE slot instead of causing a conflict with the second GPU or other peripherals making use of the x4 lanes exposed through the PCH/southbridge — which I can only assume is what was causing the problems. None of the bullshit I encountered made a lick of sense. That everything would function without a single fault and then randomly stop showing any signs of life is the most cruel bait and switch Asus could pull on me.
A cheaper x2 NVME m.2 adapter board would probably work just as well, I chose this particular PCIE4.0x16 x4m.2 board also for use in future systems and because it’s mentioned by name in the BIOS so I made the assumption it’d be the most likely to just werk™ right out of the box.
It is a very dumb utterly pointless waste of money for any x570 system that doesn’t mirror my very particular, incredibly niche setup. It is not possible to fill all four slots with drives while using any Asus x570 motherboard unless it’s installed in the top slot with a single GPU in the bottom (x4) slot, keeping the second x16 slot empty. Other motherboard manufacturers might have different implementations that do not limit systems that attempt to fully exploit all 24 available PCIE lanes of the x570 platform in the same way that Asus does but I can only comment on the hardware I’m using and the faults I continue to find creative ways to provoke.
It’s also goddamn huge, the length and width of a full size GPU.
Old post:
I have a 2tb Firecuda 520 ssd but when I installed it today and tried to use it I’d get all sorts of weird fucking errors and system lockups. After some trial and error it turns out the damn thing just dies after the write cache (1gb) fills up, past that point it’s entirely unresponsive and while files on the device can be read, nothing more can be written to it and no diagnostic software I’ve tried will even recognize the drive past that point. Seatools won’t even run but crashes on startup. Seatools is also unable to run any diagnostics on the drive even after a reboot when the cache is cleared. It’s as if the TLC NAND cells are entirely dead.
I have two of these drives, both are being returned since I have no trust in them but wanted to ask if this is an issue that’s known to occur either with this model from Seagate or any other NVME ssd’s.
Being as the drive is detected and can be accessed more or less normally provided you don’t fill up the write cache it seems improbable that this is an issue that could be caused by anything other than a failure within the drive itself. (This turned out to be false)
Update:
I now have two Samsung 970 Evo Plus drives (also 2tb each) that I tested when they arrived by writing a many dozens of gigabytes to each. I ran several VM’s off one of these drives, both worked fine and all was well.
Now a day later they’re misbehaving in the exact same way the firecuda drives did previously. It would appear then that the issue is not with the drives but something else in the system.
I have a 3950x in a crosshair VIII (x570) motherboard, two GPU’s and install the drives in the two m.2 slots found on the board. The 24 lanes available should reasonably be split x8 x8 x4 x4 (populating the top m.2 slot limits the top GPU to x8) but it’s as if the system fucking resets lane allocation after x minutes of use and kills the m.2 slots.
I’m able to see the drives in explorer as unformatted drives, they show up in disk management as formatted, diskpart doesn’t even list them. Rebooting does not improve the situation in any way.
I am at this point strongly considering ditching NVME altogether and staying with SATA. At least that is a known quantity.
I don’t know if that may be a more specific issue to those drives but it can happen wiht any drive, basically you got a DOA (Dead On Arrival) most likely the controller on the SSD is busted.
It can happen.
It wouldn’t be possible to flash the firmware and have it working again? There’s no data written to either so wouldn’t be a loss.
You can try it, but I still wouldn’t trust that drive with any important data even if it works. Though it may not be the firmaware which causes the problems it could also be the processor or whatever other components are in it.
I never trust any drive. Memory you can rely on, storage is always iffy, especially when behaving like the Seagate from OP does.
My bet would also be dead cells or some electrical/logical connection to them. Doublecheck the interwebs for similar behavior, but the behavior you mentioned after the cache is full smells fishy.
But not being able to write at all (cache doesnt really count) on a new disk just calls for RMA. I don’t expect Seagate to have major problems on their flagship consumer SSD, but sometimes hardware is just DOA no matter what brand you chose.
Do you have multiple Firecuda 520s having the same problem or is it just that single drive? With two drives freaking out, unlucky DOA is more unlikely.
This is what RMA is for
I mean. That may sound dismissive. But just don’t fall into the trap of wasting your time trying to solve something that’s simply DOA hardware.
For new not working hardware:
Dumb user mode on. Disk don’t work. Send back.
Getting new stuff working properly shouldn’t be difficult. If it is, assume it’s broken unless instructed otherwise by vendor on how to fix it.
Got two of these from a guy dismantling a threadripper system that he was selling off piecemeal, think he had ten total 2tb Firecuda 520’s with maybe a hundred terabytes written across all of them.
I installed both right off the hop when they came and set up software raid using Windows storage spaces — this is when the problems began. Although first I thought the problems originated from the use of storage spaces, eventually when I was able to delete the storage pool and access the individual drives seperately diskmgmt wouldn’t even recognize one of them. That’s when I went about testing the other that Windows could detect to see if at least it was functioning properly. That is the drive that fails every time its write cache filled up.
I have no idea what the fuck kind of problem the first drive has but at this point I have zero faith in not only either of these drives or the Firecuda line of products as a whole but Seagate in its entirety as a manufacturer of storage hardware.
Even if Seagate had firmware downloads available through their website I’m way past the point where I would consider any further troubleshooting worthwhile.
I will be pursuing a refund from the retailer they were originally purchased from (thankfully I have the receipt) and in the event I can’t just get a refund or store credit I’ll RMA both and sell off the replacements to some unlucky sap without looking at them twice.
I’m washing my hands of this whole fiasco and moving on.
Bump for visibility.
I was able to find a solution through trial & error.
While I’m glad you reported back… would you be willing to explain how you fixed it so others in the future could benefit?
All the info should be in the updated OP
tl;dr
The m.2 slots on the motherboard are fake and gay.
An m.2 adapter board has to be used in either PCIEx16_1 or PCIEx16_2 and cannot be populated with anything more than two drives. In order to function the proper settings must be configured in BIOS.
Ah, missed that edit, thanks!
Thank you for posting your solution! I’m facing a similar situaion with also the x570 Crosshair VIII motherboard. NVMe nowhere to be found in Disk Manager. I tried many other partitioning sofware to no avail. Strangely the NVMe is visible in BIOS and also in HDD Sentinel Pro, the Windows software I use to monitor my disks.
Ordered this ASUS riser board ASUS Hyper M.2 X16 PCIe 4.0 X4 Expansion Card Supports 4 NVMe M.2 to try to resolve problem. Waiting for it to arrive…
My goal is to use 2x1TB NVMe’s in RAID 0 as READ cache for a large Storage Spaces pool of HHDs containg mostly static data. I don’t trust TIERED storage (well maybe im RAID 1 mirror mode and even then…) instead of cached storage.
Added: I should also mention that the NVMe is 980 Pro. I updated the BIOS, Windows, all drivers, installed Samsung Magician, tried to upgrade the NVMe firmware (not seen), tried different BIOS settings (RAID ON/OFF, etc.) all to no avail. I also made sure that my boot SSD containing Win10 Pro was GPT (converted from MBR in case, saw a post about it). ETC… To no avail!
Also checked that Windows did not write over the NVM Express driver. No that was ok too.
Update: I was able to see the NVMe drive in Windows Disk Manager and format it by using Hard Disk Sentinel Pro (go to hdsentinel(dot)com) and following the great support message I received from its developer:
"Usually this happens when the drive previously used in a RAID environment (or for cache purpose) so generally the BIOS and/or a RAID controller stored some metadata on it. But if I’m correct, this is a new drive (showing some hours power on time only and probably not yet used).
What happens if you open Disk menu → Surface test and click on the View button to show the disk
surface map (the small squares) and click on them to view the raw data stored in the sectors?
I’d check sector #0 which should be completely empty (all zeroes). If it shows something different
then there is good chance that something stored there (maybe by the BIOS) which caused that Windows does not it.
If this is true, you may try to
  • check the BIOS setting to verify if there is any option (eg. to initialize/configure the disk drive)
  • use Disk menu → Surface test → Write test in Hard Disk Sentinel to overwrite all sectors with zeroes (no need to perform the complete operation, just start it and stop after some 1% completed, just make sure that the first sectors should be surely cleared, so the metadata should be discarded).
Ideally after a reboot, Windows Disk Management should show the disk drive as completely new
uinitialized and then it would be possible to partition/format it."
It did even before reboot! Now the problem is that Windows has “glued it” to my Storage Spaces pool and blocks anything else. I used every POwershell I know on the SS pool to no avail. It is now stuck in “rebalancing” the array including the NVMe drive that I never added to it…I’m giving up on Storage Spaces and will be going back to hardware RAID 6 as I used to do.
Oh yeah I briefly attempted to use storage spaces but learned very quickly what a horrible idea it was.
