Solution: Never install libinput and xf86-input-libinput.
The Wikis assume the mouse properties by default contain "Device" properties, however I do not get any other than libinput.
"Device" properties as in those that go for "Device Accel Profile" etc.
I've done a recent fresh install off from a LiveUSB, the hop between xorg-server 1.16 and 17 somewhat removed the basic drivers that loaded by default, as well as how there's no xorg.conf in /etc/X11.
I've tried:
# Xorg :0 -configure
just to get:
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/TTF/"
FontPath "/usr/share/fonts/OTF/"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/share/fonts/100dpi/"
FontPath "/usr/share/fonts/75dpi/"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "Accel" # [<bool>]
#Option "SWcursor" # [<bool>]
#Option "EnablePageFlip" # [<bool>]
#Option "ColorTiling" # [<bool>]
#Option "ColorTiling2D" # [<bool>]
#Option "RenderAccel" # [<bool>]
#Option "SubPixelOrder" # [<str>]
#Option "AccelMethod" # <str>
#Option "EXAVSync" # [<bool>]
#Option "EXAPixmaps" # [<bool>]
#Option "ZaphodHeads" # <str>
#Option "SwapbuffersWait" # [<bool>]
Identifier "Card0"
Driver "radeon"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
With it not being recognized if I manually change "mouse" to "evdev".
A little backstory to it was that I wanted to start anew and not bother with UEFI or EFI booting with my SSD. I also cannot register movements when they're small enough, even if I move my hand on that threshold.
This is what the mouse xinput displays:
(9 goes for Razer Orochi, seems to be detecting it as a keyboard as well now.)
$ xinput list-props 9
Device 'Razer Razer Orochi 2013':
Device Enabled (138): 1
Coordinate Transformation Matrix (140): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Accel Speed (292): 0.000000
libinput Natural Scrolling Enabled (293): 0
libinput Send Events Modes Available (256): 1, 0
libinput Send Events Mode Enabled (257): 0, 0
libinput Left Handed Enabled (294): 0
libinput Scroll Methods Available (295): 0, 0, 1
libinput Scroll Method Enabled (296): 0, 0, 0
libinput Button Scrolling Button (297): 0
Device Node (258): "/dev/input/event0"
Device Product ID (259): 5426, 57
What I'm trying to achieve is either loading the previous driver that had a LOT more properties, or just adjust to the mouse driver to be as precise as the older one. Like I said, I can move my mouse without it registering it.
I've also tried adjusting acceleration via xset, as well as the threshold for it, no success either.
"What do?"
