About a week ago, my neighbour brought her friend's PC here for me to "fix" since I've fixed a few minor things in the past on other PC's.
The problem with this one is it gets stuck on the screen where it has the "ASUS" logo in the top left, "intel" logo in the bottom right, "P5PE-VM" in the bottom center and "Press DEL to run Setuo, Press TAB to display BIOS POST Message" under all that, if I press nothing, nothing happens, so far, if I press DEL, all it says is:
AMIBIOS (C) 2006 American Megatrends, Inc etc. about the pc
Under that is:
Entering SETUP ...
DDR Frequency etc.
Checking NVRAM...
504 MB OK (Installed Memory Size:512 MB
after a while it goes into BIOS, about 3-4 minutes I'd guess and after putting in the CD (tired USB earlier) it doesn't boot from it even when I set it to boot from said device.
What can I do?
