Hello I bought all the parts to the 350 dollar build last week but now after researching which I should have done before but I trust teksyndicate so thats why I didnt but now I see the FM2-A75MA-E35 is not supported unless you use a trinity to update, But I see on the us msi website its not supported but on the global msi website it says it is supported. So is it or isnt it? I keep getting mix reviews I just dont see tek syndicate giving us a build thats not compatible. Any Clarification if it will come compatible since we are now in 2014? Thank you :)
It should work without a bios update. It depends on the vendor. Newegg has the updated ones:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130662
I bought it from the link tek syndicate had in the pc list: http://www.amazon.com/gp/product/B009HP42HQ/ref=oh_details_o01_s00_i04?i... I wish I bought it from newegg though now you think the amazon one will be updated some people say they are other say they got it when its not.
I believe that the Amazon board should be up to date. Here's a review:
"This board DOES work with Richland processors. MSI started to make these boards with the updated Bios in May of 2013. As of December 2013 Amazon Stock the boards with the newest bios that work with Richland processors. This board works fine and I have had no trouble with it. I used the AMD A-8 6600k Richland APU."
Ok yeah I read that and some others it was mix reviews but I believe you and if its not I can always send it back and get one from newegg or send it to msi and have them do whatever they do to make it the version compatible with it. Thanks man
