I use OpenMediaVault 6 with the lvm plugin, on my Desktop PC with a bunch of SSDs. I use either the GUI or Commandline to create LVM physical volumes, but /dev/sdb and /dev/sdc (all identical and functioning SSDs) don’t show up and are not found to e.g. create a volume group.
[email protected]:~# pvcreate /dev/sda /dev/sdb /dev/sdc /dev/sdd
Physical volume "/dev/sda" successfully created.
Physical volume "/dev/sdb" successfully created.
Physical volume "/dev/sdc" successfully created.
Physical volume "/dev/sdd" successfully created.
[email protected]:~# pvs
PV VG Fmt Attr PSize PFree
/dev/sda lvm2 --- 931.51g 931.51g
/dev/sdd lvm2 --- 931.51g 931.51g
Any ideas what is going on?
