Hello, all.
I’ve got Looking Glass B4 server and client on an Arch host and a freshly installed W10 guest. I’m passing my 1080 Ti through while the host uses my RX480. The lot of it seems more or less fine, except for Looking Glass. When I run the client well after Windows boots, I get the following:
[patrick@manifold-arch ~]$ looking-glass-client
[I] 17365369829 main.c:1064 | main | Looking Glass (B4+)
[I] 17365369857 main.c:1065 | main | Locking Method: Atomic
[I] 17365371934 ivshmem.c:127 | ivshmemOpenDev | KVMFR Device : /dev/shm/looking-glass
[I] 17365466435 egl.c:274 | egl_initialize | Double buffering is off
[I] 17365466453 main.c:671 | tryRenderer | Using Renderer: EGL
[W] 17365466712 idle.c:31 | waylandIdleInit | zwp_idle_inhibit_manager_v1 not exported by compositor, will not be able to suppress idle states
[I] 17365467125 gl.c:57 | waylandGetEGLDisplay | Using eglGetPlatformDisplay
[I] 17365526282 egl.c:685 | egl_render_startup | Single buffer mode
[I] 17365532711 egl.c:701 | egl_render_startup | EGL : 1.5
[I] 17365532723 egl.c:702 | egl_render_startup | Vendor : AMD
[I] 17365532732 egl.c:703 | egl_render_startup | Renderer : AMD Radeon (TM) RX 480 Graphics (POLARIS10, DRM 3.41.0, 5.13.13-arch1-1, LLVM 12.0.1)
[I] 17365532737 egl.c:704 | egl_render_startup | Version : OpenGL ES 3.2 Mesa 21.2.1
[I] 17365532741 egl.c:705 | egl_render_startup | EGL APIs : OpenGL OpenGL_ES
[I] 17365532746 egl.c:706 | egl_render_startup | Extensions: EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_EXT_buffer_age EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_swap_buffers_with_damage EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image_base EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display EGL_WL_create_wayland_buffer_from_image
[I] 17365545715 gl.c:83 | waylandEGLSwapBuffers | Using EGL_KHR_swap_buffers_with_damage
[E] 17365555831 main.c:891 | lg_run | lgmpClientSessionInit Failed: LGMP_ERR_INVALID_VERSION
I know libgmp is for math to arbitrary precision, but perhaps that’s not even the library being used here? (After all, lg_run is Looking Glass Run.) Other than that, I’m clueless as to what’s amiss.
Any pointers would be greatly appreciated. =)
