I’m running the LVL1Tech’s KVM. It’s worked like a top for several years now. But all of a sudden I’m getting random drop outs of 2nd monitor (I have the dual monitor one) SQ2625416 (DP 1.2)
i’ve swapped monitors around, using either high quality (supposedly) cables as well as dell default. All of these cables have worked like a top since 2019, even a newer longer set (which I’ve pulled out of the loop to validate). It does seem to be my “right monitor” with weird issues with MFT (I’m using a USBC dock for my work and *nix laptops).
I have the same issue on my linux workstation with the same no display port signal as I do with my Windows workstation. (hence the two 1080’s 1each) Windows started after 20h2 update but now I’m getting the same issue on both.
one odd behaviour, my win10 workstation will occasionally work, then sleep and then only report black screens even after reboot, on multiple graphics cards (including Quatro’s) a gtx1060, as well as onboard Intel graphics. so reboot reports black screen continuously.
On both linux wkstn and laptop I will regularly get a single monitor to display ( R monitor).
Various generation quatro’s used, gtx1060, 2x1080’s, onboard intel graphics. Linux, BSD, and Win10.
The oddest thing is my Win10 work laptop will display both monitors correctly 90% of the time through the same USB c dock, $60 cable matters.
The key to all of this, this has worked flawlessly for 2 years with the same cables (I’ve removed new cables to validate) Multiple OSes, etc.
Sorry for the rambling this is a note dump and I’ll add more troubleshooting (direct connect to monitors next)
details and individual systems tested
SQ2625416 - DP 1.2 dual monitor KVM
Intel 6700k + 1080 + asus sabertooth
LG Gram (2021) + cable matters usb c dock
Dell lattitude 5400 + cable matters usb c dock
Chinese franken dual xeon + 1080
Dell 7010
Razer egpu enclosure + 1060 connected to LG gram
Unfortunately this is killing me as my VM’s were on vmware workstation on the win10 machine for a security class I’m running through and I’m also working 70hrs a week doing security and need to get these all working (KVM is essential lest I have 50 monitors and 10 keyboards)
