[Solved]Is my Corsair AX-760i Dead?
Ok, I bought a Corsair AX-760i PSU off Amazon.com. It finally came. Now my motherboard, ram were installed in the case, but i havent bought anything else yet because im stlls saving up. I live in Australia so the PSU was naturally sent with the American wall plug, so i took the liberty of buying an Australian wall plug. Now this PSU comes with a "self test" button. So i plugged in all the hardware that i have and then tryed to "self test" button. I heard a tick noise and a faint spin or something, and the green led on my motherboard lit up. But according to the setup guide, the led on the psu should light up as well, and it said that if it doesnt, contact corsair tech support. Please can someone tell me if this psu is dead and if i have to rma it, i dont want to wait untill my system is fully built and then i boot it up and it doesnt work.
Please Help!!! and i will put the specs of what my system will be like down below.
Intel Core i7-3770K
G.Skill Ripjaws-X 16Gb 1600Mhz
Asus P8Z77-V PRO
Gigabyte GeForce GTX 670 2GB WF3 OC
OCZ Vertex 4 256Gb SSD
Seagate Barracuda 2TB 7200RPM 64Mb
Thermaltake Chaser MK-1 Full Tower Case
Corsair H100i CPU Cooler
LG BluRay Combo Drive
THANKS!
I would do as it says and contact the corsair support. It is fairly unlikely that the psu is dead however as corsair is generally a trustworthy brand for these kinds of products. Another thing you could do is to hook the psu up to an old computer that you might have and see if it turns on. for all you know the led on the psu is faulty, in which case the actual psu should work fine.
alright, thanks, i might try that mate :) Hopefully its not dead
Ok, i didnt tell you but i also made a thread on Corsairs Forums and there Tech support helped me fix the problem, i had to unplug all the cables and try it and it worked, but thanks anyways :)
