I’m going to play around with it some more tomorrow, but thought I would pose the question in case anyone else has already done the legwork:
I’m trying to install discord on Fedora and can’t seem to either obtain the tar.gz from discord, or they don’t have one. I also tried using alien to convert the deb to rpm, but there seem to be quite a few missing dependencies. As a side note, I’m familiar with Debian distros, but super-noob to Red Hat distros. Any thoughts or advice for things to try?
I had it working a while back- best I can say is that the version I had installed was Discord Canary. I tried to find it with a quick search to no avail.
I used the software app and it installed fine called “Discord Canary”. Discord seems to update itself when launched after that. I rarely use it however.
Discord messed up the download for that specific time period where it only provided the .deb package even if you downloaded the .tar.gz but kept the filename the same, If you uncompressed the tarball you’d find the deb package file structure. it fixed its self soon after that.
Under Ubuntu 17.10, Discord on two separate occasions using 2 different versions of discord had my mic turned on without me knowing it. People could hear what I was doing and I had no idea until someone told me.
Imagine the things you say and do in front of your computer when you think nobody can see or hear you.
Yeah, I’ll not be reinstalling discord for a while, if ever.
Sorry. Having different issues, but still haven’t gotten it fully functional yet. @MichaelLindman was right about the tar.gz giving me the deb anyway, but that’s resolved now. (Discord’s site works again as well, so now I look like a crazy person…)
Unfortunately, now that I’ve installed it using the tar.gz, I’m getting the same issues a lot of people had about a year ago on the windows version. That is, I only get a gray (blank) window, and nothing else.
On another hand, I tried an alternate method on Windows 2012r2 (The only other OS I’m running simultaneously), and it works, but discord thinks the install is corrupt, after doing a fresh install with multiple downloads of the install media. Lol I can’t win.
Edit: As a side note, I have a lot going on during the workweek, so I only get about 2-3 hrs of playing/fixing/eating before I need to sleep again for work. Sorry if the delays in between are too long.
