Ok, I’m a complete noob, <3 weeks in Linux so go easy on me.
I’ve got a working SATA SSD from old MacPro which is now dead. I want all the pictures and files off it.
Boot to windows it doesn’t see the Mac Partition. Disk has two partitions PCHD (NTFS) and MacbookPro (Mac formatted).
Boot to Elementry OS and I see the folders on both partitions, but on mac partition it won’t let me open the folders in the file manager. It says “This folder does not belong to you, you don’t have permission to view this folder”
I googled and found i’m supposed to do something like this somehow:
cd ~/Desktop
sudo chown tati.tati *
Where “tati” is user see link to forum here:
ubunto forum
BUT… I’m such a noob I don’t even know how to get to the partition on the MacPro HD.
google says I’m supposed to:
sudo mount /dev/sdc2 /media/pianopraze/MacbookPro
but it doesn’t work. It says:
mount: /dev/sdc2 is already mounted or /media/pianopraze/MacbookPro busy
/dev/sdc2 is already mounted on /media/pianopraze/MacbookPro
Here is what I have:
pianopraze@ElementryOS:/$ ls
bin dev initrd.img lib64 mnt root srv usr vmlinuz.old
boot etc initrd.img.old lost+found opt run sys var
cdrom home lib media proc sbin tmp vmlinuz
pianopraze@ElementryOS:/$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sdb 8:16 0 2.7T 0 disk
└─sdb1 8:17 0 2T 0 part
sr0 11:0 1 1024M 0 rom
sdc 8:32 0 931.5G 0 disk
├─sdc2 8:34 0 875G 0 part /media/pianopraze/MacbookPro
├─sdc3 8:35 0 619.9M 0 part
├─sdc1 8:33 0 200M 0 part
└─sdc4 8:36 0 55.8G 0 part /media/pianopraze/PCHD
sda 8:0 0 18.7G 0 disk
├─sda2 8:2 0 1K 0 part
├─sda5 8:5 0 18.2G 0 part
│ ├─elementary--vg-swap_1
│ │ 253:1 0 3.5G 0 lvm [SWAP]
│ └─elementary--vg-root 253:0 0 14.7G 0 lvm /
└─sda1 8:1 0 487M 0 part /boot
pianopraze@ElementryOS:/$ sudo mount /dev/sdc2 /media/pianopraze/MacbookPro
[sudo] password for pianopraze:
sdb is Windows SSD
sdc is the MacPro SSD I want to copy files from
sda is ide drive with Elementary installed on it.
So… I can’t get it working and put all this info together. I feel so stupid… Help?
I need to get to the MacbookPro hard drive and change the permissions.
