I am trying to install Odysseus following the guide on the website. I have gotten as far as being able to access the web console and I am now trying to connect to Ollama.
In step three the guide says to run OLLAMA_HOST=0.0.0.0:11434 ollama serve which I do and I get the following error message Error: listen tcp 0.0.0.0:11434: bind: address already in use.
Reading online this seems to be a common issue with new installs and I believe I can just ignore that message.
I tried running sudo systemctl edit ollama per the guide and removed everything that was in the Environment line ATH=/home/BWMerlin/.local/bin:/home/BWMerlin/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin and replaced it with “OLLAMA_HOST=0.0.0.0:11434” followed by running sudo systemctl restart ollama.
After that I went into the Odysseus console, into settings and added http://host.docker.internal:11434/v1 as the URL for the local model but I keep getting an error when trying to probe the model that it is not being found.
What have I missed/messed up? I am running Fedora Workstation 44 fully patch as of 23-08-2026 and Odysseus is running inside of docker.
