Solution:
Described in this reply:
Settings for BIOS version F38:
Alternative fix by @Bedna , which may work in some cases, or at least give You a chance to POST and get into bios:
If you experience “weird” issues during heavy load, or even normal operation and use water cooling, you might benefit from providing extra cooling to chipset and RAM.
Thanks for @J_S1 for this info, details:
Original post:
Greetings,
I have foolishly built a system using this motherboard. It had some problems from the start (I do not exactly remember, since it was a year ago), but recently, it just continues to drive me mad and consume a lot of time to do anything with it.
If anyone has experienced similar issues and managed to solve them - please let me know how. It seems like my sanity is slowly deteriorating.
Hardware config:
- 64GB ram - chosen from “supported dram” list to avoid problems - 2x G-SKILL F5-6000J3040G32G
- CPU: Ryzen 7900 (no X)
- GPU: XFX Radeon 6700 XT
- A good PSU (850 Wats, quality brand, don’t remember which, difficult to check right now)
- NVME 1TB WesternDigital - WDS100T3XHC-00SJG0 - for windows 11, in slot “C”
- NVME 1TB Samsung 980 - for use with QubesOS, in slot “A”
- NVME 1TB Samsung 990 Pro - for use with QubesOS, in slot “B”
- MS Sculpt ergo keyboard + mouse
- SVM, IOMMU: Enabled
Problems:
- Sometimes it just doesn’t start (hangs at logo screen / text screen when logo is turned off)
- Sometimes it starts, but does not detect M2 drive in slot C
- Sometimes it starts, but keyboard and mouse do not work (for the purpose of bios update) - unable to select boot dev or enter bios
- Sometimes it starts, but no USB flash drives are found (for the purpose of bios update)
- Most of the time mouse works especially slowly in BIOS
- Most of the time BIOS works especially slowly overall
- Upon connecting SAS controller it takes ages to start booting (LSI SAS 9217) - currently disconnected.
- Qubes OS fails to boot most of the time (it just reboots).
(When mentioning slow boot, I do not mean the “ram training” delay - I mean the amount of time it takes just to show a logo)
Attempted remedies:
- Various BIOS versions from F11 to F 32g
- Disabling secure boot
- Disabling pcie power mamagement
- Removing LSI controller
- Turning on “fast boot”
- Turning off “fast boot”
- Turning EXPO on/off - no meaningful difference
- Moving M2 drive used by win 11 from slot D to slot C (this has somewhat improved my chances of booting into windows)
The funny thing is, that when it manages to boot - it works! It is stable, nothing crashes, can sustain stress tests like prime95 or furmark with no issue.
For this reason I mainly use “sleep” function… dreading the time when winupdate comes my way, or power fails.
Shall I get a new MB?
