Hi all,
My server is spitting out an error saying “failed to load ldlinux.c32” and thus the system wont continue the boot process. After some help on the unraid forum they said to rebuild the USB using the fsck command under linux
the only issue is that im still new to Ubuntu and cart quite understand the response that the terminal is giving me. Can anyone ‘translate’?
Thanks
[email protected]:~$ sudo fsck /dev/sdd1
[sudo] password for jjackstar:
fsck from util-linux 2.30.1
e2fsck 1.43.5 (04-Aug-2017)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks…
fsck.ext2: Bad magic number in super-block while trying to open /dev/sdd1
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193
or
e2fsck -b 32768
