Hello,
I am new here and tried my hardest to find the best section to post this in. Also used search.
I was wondering if there is a program native to Ubuntu that will be able to measure the FPS output of gameplay? I have a channel on youtube that I post raw capture footage. I thought it would be nice to have a global program that I can over lay on top of the game to show FPS. Is this a per game basis?
Thanks,
My Channel
If you are using Steam, go to Settings > In-Game and check the box to show fps.
This pretty much.
And this also works for non-steam games if you added them to steam.
In case you are playing games through WINE with DXVK or D9VK, you can enable FPS (and also Frametimes and a lot of other statistics) by using environment variables for them.
DXVK_HUD=fps,compiler,frametimes
Is pretty much my go to, except for singleplayer stuff where I just disable it alltogether.
