So I’m trying to format an external drive, specifically a USB drive, for GPT or MBR specifically and I keep getting this weird error message saying the specified disk is not convertible. Just wondering if there’s a different command I should be using or something or whatever it would be to get it working. (Yes, I ran command prompt as an admin)
Nevermind…
For some odd reason, you have to use the “clean” command before you can use the “convert” commands.
Ended up working.
