You could do a paperclip test to see if the psu works.
No, i'll google it
Okay. Do the paperclip thing too if that doesn't work (Stated above)
Just make sure everything is unplugged from the power supply
If none of this works you might see if you have an out of place stanchion. Could be grounding out the board.
Shorted the pins and it turned everything on. will I have to do that every time to turn it on?
That means that you have found the source of your problem. Make sure that the front panel connectors are connected correctly. If it still doesn't work, something between the connector and front panel could be broken. If the case still has a warranty you could probably return it to get it repaired or get a new one.
So it turns i'm just stupid and kept pressing the reset button instead of the power switch. But I got working now so that's all that matters. thanks for all the help everyone I really appreciate it.
sweet good find
we've all been there
good then i will mark it as solved.
