Build: https://pcpartpicker.com/user/Mellotix/saved/ AMD FX-8350 4.0GHz 8-Core Processor Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ASRock 970M PRO3 Micro ATX AM3+/AM3 Motherboard Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive Sapphire Radeon R9 390 8GB Nitro Video Card Cooler Master N200 MicroATX Mid Tower Case EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Just assembled my first build and it won't turn on. And by turn on I mean I press the power button and nothing what so ever happens, not a continuous reboot loop or whatever as iv'e read in other threads.
I built it originally 2 weeks ago but still had the same problem of it not turning on so I took it to a "professional" to diagnose and he said my motherboard was dead. So I sent it back, got a refund, and installed my new one yesterday, and the problem persists.please help I just wanna play video games ;_;
Are your front panel connectors connected correctly? Find the two that are meant for the power button and short them with like a screw driver. See if it boots ghat way. Also like triple check ALL power connectors to make sure they are fully plugged in
its most likely a power issue. If ram or graphics card is not seated correctly, then atleast the cpu fan and eventual lights on the mobo should light up.
Re-seat the 24pin atx power connector and also the 8 pin cpu power connector
