Howdy,
I am trying to set up a home server (using a Xeon E5 2630L v3) with what seems like a classic configuration : docker as a base, portainer to manage the containers and Nginx (also in a docker container) as a reverse-proxy. The first container I want to use is nextcloud.
I have also a RPi3 running pi-hole,works as my DHCP server and with unbound, no issue up to this point.
I managed to get portainer, nextcloud and nginx proxy manager installed. I can access nextcloud on port 8080, portainer on port 9000 and nginx reverse proxy on port 81. I see everything running in portainer.
The issue however is the reverse proxy functionality. For now I only want the server to work on my local network. So I added nextcloud.testdomain.fr and mapped it to the server local IP address in the pi-hole Local DNS/DNS Records page. In Nginx Proxy Manager I created a proxy host with nextcloud.testdomain.fr as source and nextcloud_app_1:80 as destination. I did the same for portainer and nginx.
Now if I connect to the the server IP, I see the nginx 404 page as expected. However, when I try to connect to nextcloud.testdomain.fr I see the default “Welcome to nginx!” page instead of the nextcloud interface.
I am at the point where, in the documentation I found, it should “just work” but I does not, and I do not know what to try anymore or what the issue can be : pi-hole setup, nginx setup or containers setup. I am also intrigued by the “Welcome to nginx!” page I see, because I would either expect the 404 error as configured or the appropriate nextcloud/nginx/portainer web UI.
Can someone gives me something to check to try to debug this ?
Thanks for your help
