[Solved] Dell S6000 40GbE basic setup
TL;DR - I’m clearly missing something in my switch config, I can’t get basic L2 routing working correctly. I have ping and ssh working, but any attempt to move traffic beyond a few KB/s kills the socket.
[solution]
I set MTU to 9000 everywhere and it still failed. I then set the switch to 12000 (its internally stated max) and the clients to 9000 and now it works)
Dell(conf)interface fortyGigE 0/0
Dell(conf-if-fo-0/0)#mtu 12000
Dell(conf-if-fo-0/0)#interface fortyGigE 0/8
Dell(conf-if-fo-0/8)#mtu 12000
Dell(conf-if-fo-0/8)#interface fortyGigE 0/4
Dell(conf-if-fo-0/4)#mtu 12000
Dell(conf-if-fo-0/4)#interface fortyGigE 0/12
Dell(conf-if-fo-0/12)#mtu 12000
I’m guessing that 9000 + ~100-300b would have worked as well since that’s what I recall the linux kernel/driver bug missing in its header computation…
I’ve managed to factory reset my ebay’d S6000 switch by interrupting the boot:
(esc)
BOOT_USER# ignore enable-password
BOOT_USER# reload
(normal boot)
Dell>enable
Dell#restore factory-defaults stack_unit all clear_all
I then connected exactly 2 linux machines to ports 0 and 8. These two machines are running Mellanox VPI adaptors set to “eth” mode. For reference, here is a single threaded iperf with those two machines connected point-to-point with a copper QSFP cable:
# iperf3 -c 10.6.9.20
Connecting to host 10.6.9.20, port 5201
[  4] local 10.6.9.22 port 39030 connected to 10.6.9.20 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  2.47 GBytes  21.2 Gbits/sec    0    866 KBytes
[  4]   1.00-2.00   sec  2.75 GBytes  23.6 Gbits/sec    0    866 KBytes
[  4]   2.00-3.00   sec  2.75 GBytes  23.6 Gbits/sec    0    866 KBytes
[  4]   3.00-4.00   sec  2.75 GBytes  23.6 Gbits/sec    0    866 KBytes
Here are the setup steps I’ve taken with the switch
Dell>enable
Dell># conf
(conf)stack-unit 0 provision S6000
(config)interface fortyGigE 0/0
(conf-if-fo-0/0)#no shutdown
(conf-if-fo-0/0)#switchport
(config)interface fortyGigE 0/8
(conf-if-fo-0/8)#no shutdown
(conf-if-fo-0/8)#switchport
I can ping:
PING 10.6.9.22 (10.6.9.22) 56(84) bytes of data.
64 bytes from 10.6.9.22: icmp_seq=1 ttl=64 time=0.117 ms
64 bytes from 10.6.9.22: icmp_seq=2 ttl=64 time=0.087 ms
64 bytes from 10.6.9.22: icmp_seq=3 ttl=64 time=0.099 ms
64 bytes from 10.6.9.22: icmp_seq=4 ttl=64 time=0.120 ms
64 bytes from 10.6.9.22: icmp_seq=5 ttl=64 time=0.114 ms
I can ssh and do simple commands without issue:
ssh [email protected]
# cd /bin
# ls
abrt-action-analyze-backtrace
abrt-action-analyze-c
abrt-action-analyze-ccpp-local
abrt-action-analyze-core
abrt-action-analyze-oops
abrt-action-analyze-python
abrt-action-analyze-vmcore
HOWEVER, any higher bandwith activity hangs the link:
[  4] local 10.6.9.22 port 39002 connected to 10.6.9.20 port 5201
[  4]   0.00-1.00   sec  6.25 MBytes  52.4 Mbits/sec    2   8.75 KBytes
[  4]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec    1   8.75 KBytes
[  4]   2.00-3.00   sec  0.00 Bytes  0.00 bits/sec    0   8.75 KBytes
[  4]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec    1   8.75 KBytes
[  4]   4.00-5.00   sec  0.00 Bytes  0.00 bits/sec    0   8.75 KBytes
The “hang” appears to function on a socket level… ^C on iperf then allows ping to work afterward.
stack-unit 0 quad-port-profile 0,8,16,24,32,36,40,44,48,52,56,60,64,68,72,76,80,84,88,92,100,108,116,124
 no ip address
 switchport
 no shutdown
 no ip address
 switchport
 no shutdown
EDIT: I’ve tried ports 8 &12 as well - identical result
I also see no errors/drops reported on the client interfaces:
ens1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 9000
        inet 10.6.9.22  netmask 255.255.255.0  broadcast 10.6.9.255
        RX packets 147973  bytes 8946946 (8.5 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 2312667  bytes 20721437985 (19.2 GiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Welll… MTU=9000 appears to be the problem…
but why??? Does this switch really not support jumbo packets over 40GbE?
I disabled that and now:
iperf3 -c 10.6.9.20 -P 8
[  4]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[  4]   0.00-10.00  sec  4.64 GBytes  3.98 Gbits/sec                  receiver
[  6]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[  6]   0.00-10.00  sec  4.64 GBytes  3.98 Gbits/sec                  receiver
[  8]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[  8]   0.00-10.00  sec  4.64 GBytes  3.98 Gbits/sec                  receiver
[ 10]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[ 10]   0.00-10.00  sec  4.63 GBytes  3.98 Gbits/sec                  receiver
[ 12]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[ 12]   0.00-10.00  sec  4.63 GBytes  3.98 Gbits/sec                  receiver
[ 14]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[ 14]   0.00-10.00  sec  4.63 GBytes  3.98 Gbits/sec                  receiver
[ 16]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[ 16]   0.00-10.00  sec  4.63 GBytes  3.98 Gbits/sec                  receiver
[ 18]   0.00-10.00  sec  4.65 GBytes  3.99 Gbits/sec    0             sender
[ 18]   0.00-10.00  sec  4.63 GBytes  3.98 Gbits/sec                  receiver
[SUM]   0.00-10.00  sec  37.2 GBytes  31.9 Gbits/sec    0             sender
[SUM]   0.00-10.00  sec  37.1 GBytes  31.8 Gbits/sec                  receiver
Gotta be something else you need for jumbo packets, a 40GbE switch without jumbo packets is like a 150 Mbps connection with a 1TB data limit.
Oh…
Very much that… Given that high-speed NFS for large (many gigabyte) files for my personal compute cluster is my reason for this link…
and to completely answer my own question - the issue is a two-parter:
  1. the default MTU is 1554
  2. Whatever you set, you may need to leave head-room for linux to “fudge” the MTU. I vaguely recall a bug where some header math was done incorrectly on MTU which caused 10GbE cards to malfunction with 9000 MTU
You need to configure the MTU on the switch ports as well. We use 9126 on appliances which have a similar switch.
40 Gbps / 1500 bytes is 3.33 million packets per second… 300ns is roughly 1000cycles per packet per core… that should be plenty, no?
1500 vs 9000 MTU took a big bite out of 10GbE NFS performance when “streaming” (aka: block-wise sequential access of) large files which is my primary use-case. Given the underlying cause of this (kernel churn on packet processing hitting limits (“packets per second” vs GHz to process them), I would expect nearly identical scaling of Jumbo vs non in 40G we see with 10G.
RDMA may render this moot - I haven’t set that up yet.
Have you compared NFS to e.g. just catting the file with mbuffer or similar?
No, but I’m not sure what this would provide me? Sorry if I confused, but my reference to “sequential” access was to describe the flavor, but not the entire function of my desire to optimize NFS access.
My desired functionality isn’t just blind transmit/receive of files, but rather has embedded functionality/caching that minimizes random access and caters to the tendency of the application to desire/process large sequential blocks (MBs to GBs) at a time. That data is also manipulated once pulled from the disk, prior to being used, so there is a benefit of minimizing churn to-from disk of a given region.
Whether the actual application or dd, 10GbE showed significant (it’s been a while, but on the order of 20-30% IIRC) performance delta with jumbo vs non-jumbo frames. Not alone in that, hence Intel’s app-notes for optimizing 10GbE connections.
