*solved* Corsair H100i + AX860 = not true?
Have just started building my first PC and have bought the H100i liquid CPU cooler and the AX860. But I can´t find a cable from the AX860 that connects with the power cable from the H100i. Have I just messed it all up; arent´t these to components compatible?
The power cable on the H100i is a SATA power connector. Use one of the SATA power connections from your AX860.
Wow, I didn´t know that, Batojiri! I tried it early before posting, but it seemed to me it didn´t fit. But with a little confidence from your side, it just needed some force before it slid into each other. Seriously, you made my day :)
No problem, everybody has brain farts from time to time. Glad to help.
