I cloned the manjaro install from my laptop (Intel CPU and iGPU) to a desktop machine (Ryzen and R9 Fury). It is booting, I can SSH into it but it won’t start the GUI. I do have amdgpu installed though.
lspci
says driver is fine, if I understand this correctly.
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Fiji [Radeon R9 FURY / NANO Series] (rev cb) (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited / Sapphire Technology Fiji [Radeon R9 FURY / NANO Series]
Flags: bus master, fast devsel, latency 0, IRQ 54
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=2M]
I/O ports at d000 [size=256]
Memory at fe900000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: amdgpu
Kernel modules: amdgpu
dmesg | grep amdgpu
gives me this which … might help … maybe?
[ 7.167481] [drm] amdgpu kernel modesetting enabled.
[ 7.178745] fb: switching to amdgpudrmfb from EFI VGA
[ 7.179198] amdgpu 0000:07:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
[ 7.179244] amdgpu 0000:07:00.0: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
[ 7.179245] amdgpu 0000:07:00.0: GTT: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 7.179321] [drm] amdgpu: 4096M of VRAM memory ready
[ 7.179322] [drm] amdgpu: 4096M of GTT memory ready.
[ 7.431305] fbcon: amdgpudrmfb (fb0) is primary device
[ 7.451644] WARNING: CPU: 0 PID: 375 at drivers/gpu/drm/amd/amdgpu/../display/dc/dm_services.h:132 generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.451645] Modules linked in: bnep amdkfd amd_iommu_v2 amdgpu(+) nls_iso8859_1 nls_cp437 vfat fat joydev mousedev input_leds uvcvideo(+) snd_hda_codec_hdmi edac_mce_amd videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 kvm_amd videobuf2_common snd_hda_intel ccp videodev snd_hda_codec rng_core chash kvm gpu_sched ttm snd_usb_audio btusb btrtl drm_kms_helper btbcm btintel eeepc_wmi snd_usbmidi_lib bluetooth asus_wmi irqbypass media snd_hda_core crct10dif_pclmul snd_rawmidi crc32_pclmul sparse_keymap ghash_clmulni_intel led_class wmi_bmof snd_hwdep mxm_wmi pcbc snd_seq_device drm snd_pcm igb ecdh_generic aesni_intel rfkill snd_timer aes_x86_64 agpgart snd crypto_simd glue_helper syscopyarea i2c_algo_bit sysfillrect sysimgblt dca fb_sys_fops soundcore cryptd pcspkr i2c_piix4 k10temp shpchp rtc_cmos
[ 7.451710] RIP: 0010:generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.451751] ? generic_reg_update_ex+0xe6/0x150 [amdgpu]
[ 7.451786] ? set_pixel_encoding.isra.0+0x1f3/0x200 [amdgpu]
[ 7.451819] ? amdgpu_cgs_read_ind_register+0xb0/0xb0 [amdgpu]
[ 7.451853] dce110_update_generic_info_packet+0x64/0x3c0 [amdgpu]
[ 7.451886] dce110_stream_encoder_update_dp_info_packets+0x1e3/0x210 [amdgpu]
[ 7.451919] apply_single_controller_ctx_to_hw+0x247/0x360 [amdgpu]
[ 7.451952] dce110_apply_ctx_to_hw+0x428/0x740 [amdgpu]
[ 7.451982] ? generic_reg_update_ex+0xe6/0x150 [amdgpu]
[ 7.452017] dc_commit_state+0x2e6/0x530 [amdgpu]
[ 7.452048] ? mod_freesync_set_user_enable+0x119/0x150 [amdgpu]
[ 7.452082] amdgpu_dm_atomic_commit_tail+0x372/0xdb0 [amdgpu]
[ 7.452111] ? amdgpu_bo_pin_restricted+0x1f9/0x2c0 [amdgpu]
[ 7.452143] ? dm_plane_helper_prepare_fb+0x1da/0x240 [amdgpu]
[ 7.452215] amdgpu_fbdev_init+0xc4/0xf0 [amdgpu]
[ 7.452242] amdgpu_device_init+0xcba/0x1310 [amdgpu]
[ 7.452271] amdgpu_driver_load_kms+0x86/0x2b0 [amdgpu]
[ 7.452305] amdgpu_pci_probe+0xff/0x190 [amdgpu]
[ 7.461865] WARNING: CPU: 0 PID: 375 at drivers/gpu/drm/amd/amdgpu/../display/dc/dm_services.h:132 generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.461865] Modules linked in: bnep amdkfd amd_iommu_v2 amdgpu(+) nls_iso8859_1 nls_cp437 vfat fat joydev mousedev input_leds uvcvideo(+) snd_hda_codec_hdmi edac_mce_amd videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 kvm_amd videobuf2_common snd_hda_intel ccp videodev snd_hda_codec rng_core chash kvm gpu_sched ttm snd_usb_audio btusb btrtl drm_kms_helper btbcm btintel eeepc_wmi snd_usbmidi_lib bluetooth asus_wmi irqbypass media snd_hda_core crct10dif_pclmul snd_rawmidi crc32_pclmul sparse_keymap ghash_clmulni_intel led_class wmi_bmof snd_hwdep mxm_wmi pcbc snd_seq_device drm snd_pcm igb ecdh_generic aesni_intel rfkill snd_timer aes_x86_64 agpgart snd crypto_simd glue_helper syscopyarea i2c_algo_bit sysfillrect sysimgblt dca fb_sys_fops soundcore cryptd pcspkr i2c_piix4 k10temp shpchp rtc_cmos
[ 7.461923] RIP: 0010:generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.461959] ? generic_reg_update_ex+0xe6/0x150 [amdgpu]
[ 7.461992] dce110_update_generic_info_packet+0x64/0x3c0 [amdgpu]
[ 7.462029] dce110_stream_encoder_update_dp_info_packets+0x1e3/0x210 [amdgpu]
[ 7.462062] dce110_enable_stream+0x51/0xd0 [amdgpu]
[ 7.462093] core_link_enable_stream+0x1a1/0xc40 [amdgpu]
[ 7.462124] ? dce110_update_generic_info_packet+0x30e/0x3c0 [amdgpu]
[ 7.462157] ? amdgpu_cgs_read_ind_register+0xb0/0xb0 [amdgpu]
[ 7.462187] ? dce110_stream_encoder_update_dp_info_packets+0x155/0x210 [amdgpu]
[ 7.462219] apply_single_controller_ctx_to_hw+0x294/0x360 [amdgpu]
[ 7.462249] dce110_apply_ctx_to_hw+0x428/0x740 [amdgpu]
[ 7.462279] ? generic_reg_update_ex+0xe6/0x150 [amdgpu]
[ 7.462310] dc_commit_state+0x2e6/0x530 [amdgpu]
[ 7.462340] ? mod_freesync_set_user_enable+0x119/0x150 [amdgpu]
[ 7.462373] amdgpu_dm_atomic_commit_tail+0x372/0xdb0 [amdgpu]
[ 7.462400] ? amdgpu_bo_pin_restricted+0x1f9/0x2c0 [amdgpu]
[ 7.462432] ? dm_plane_helper_prepare_fb+0x1da/0x240 [amdgpu]
[ 7.462505] amdgpu_fbdev_init+0xc4/0xf0 [amdgpu]
[ 7.462534] amdgpu_device_init+0xcba/0x1310 [amdgpu]
[ 7.462562] amdgpu_driver_load_kms+0x86/0x2b0 [amdgpu]
[ 7.462596] amdgpu_pci_probe+0xff/0x190 [amdgpu]
[ 7.471339] WARNING: CPU: 0 PID: 375 at drivers/gpu/drm/amd/amdgpu/../display/dc/dm_services.h:132 generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.471339] Modules linked in: bnep amdkfd amd_iommu_v2 amdgpu(+) nls_iso8859_1 nls_cp437 vfat fat joydev mousedev input_leds uvcvideo(+) snd_hda_codec_hdmi edac_mce_amd videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 kvm_amd videobuf2_common snd_hda_intel ccp videodev snd_hda_codec rng_core chash kvm gpu_sched ttm snd_usb_audio btusb btrtl drm_kms_helper btbcm btintel eeepc_wmi snd_usbmidi_lib bluetooth asus_wmi irqbypass media snd_hda_core crct10dif_pclmul snd_rawmidi crc32_pclmul sparse_keymap ghash_clmulni_intel led_class wmi_bmof snd_hwdep mxm_wmi pcbc snd_seq_device drm snd_pcm igb ecdh_generic aesni_intel rfkill snd_timer aes_x86_64 agpgart snd crypto_simd glue_helper syscopyarea i2c_algo_bit sysfillrect sysimgblt dca fb_sys_fops soundcore cryptd pcspkr i2c_piix4 k10temp shpchp rtc_cmos
[ 7.471398] RIP: 0010:generic_reg_update_ex+0x108/0x150 [amdgpu]
[ 7.471440] dce110_update_generic_info_packet+0x64/0x3c0 [amdgpu]
[ 7.471473] dce110_stream_encoder_update_dp_info_packets+0x1e3/0x210 [amdgpu]
[ 7.471504] dc_stream_adjust_vmin_vmax+0xb3/0xf0 [amdgpu]
[ 7.471534] set_freesync_on_streams.part.4+0x173/0x220 [amdgpu]
[ 7.471564] mod_freesync_notify_mode_change+0x11e/0x150 [amdgpu]
[ 7.471597] amdgpu_dm_atomic_commit_tail+0x53c/0xdb0 [amdgpu]
[ 7.471624] ? amdgpu_bo_pin_restricted+0x1f9/0x2c0 [amdgpu]
[ 7.471656] ? dm_plane_helper_prepare_fb+0x1da/0x240 [amdgpu]
[ 7.471722] amdgpu_fbdev_init+0xc4/0xf0 [amdgpu]
[ 7.471748] amdgpu_device_init+0xcba/0x1310 [amdgpu]
[ 7.471777] amdgpu_driver_load_kms+0x86/0x2b0 [amdgpu]
[ 7.471810] amdgpu_pci_probe+0xff/0x190 [amdgpu]
[ 7.488765] amdgpu 0000:07:00.0: fb0: amdgpudrmfb frame buffer device
[ 7.501232] [drm] Initialized amdgpu 3.23.0 20150101 for 0000:07:00.0 on minor 0
Any ideas? Do I have to kick some Intel stuff or rm a config or so?
