I'm building a PC and I kinda know what I want. But I'm really struggeling about which GPU to take (Limit is $230). Does someone knows a great GPU for my pc? And yes, I'm going to overclock
The contest cards in those price ranges are the GTX660 and the HD7870, they both battle for that range in price and depending on what games you want to play will depend on which card you get. Here is a bench of a bunch of games at various resolutions of both cards for comparison: http://www.anandtech.com/bench/Product/548?vs=660
The GTX660 has the price lead so far at $200 for the cheapest one vs $215 for the HD7870, take a look at the bench and judge which plays the games you like at the best fps you like. The cards trade blows with each other well, in some games the HD7870 pulls a bit, in others the GTX660 pulls a bit as well, you can not go wrong with either card honestly.
If your max is 230 i'd personally buy a 660, the performance between the two cards is similar, you get physx, CUDA, better drivers. Downsides being the small memory bus width on the 660 will limit your OC potential, and eyefinity being unavailable to you.
But in youe position i'd scrounge together an extra $30 and buy a 7870ghz MSI HAWK for $260.
Will this work? I mean like it will not bottleneck because of my CPU? This does fit in my price range, And the HD7950 is a pretty good card. Or are there better cards for 280 dollars?
Yes it would work and bottlenecking it is possible with the fx4100, can you include the prices you are paying for it? We can help you find a better processor close to it's range for you.
The HD7950 is a direct competitor to the GTX660Ti, it is the same case with the 7870 vs 660. On some games the 7950 pulls and on others the 660ti pulls: http://www.anandtech.com/bench/Product/550?vs=647
The GTX660Ti has the price lead at $245 mark while the 7950 starts at $275, so the GTX660ti to me offers a bit of a better deal at the moment only because the 7950 is a bit to high. Do not be fooled, either of these cards will do serious gaming damage, ultimately it is a matter of preference and use.
Oc'd 7950's are at or above GTX 670 performance, and some of the better Custom GTX 660ti's can get near there as well, theyre really is no wrong choice here, what games wil you be playing ?
Here is a link to a fx4100 agaisn't a bunch of others, it seems the Phenom II series is faster then the FX4100 by a good bit :http://www.guru3d.com/articles_pages/amd_fx_8150_8120_6100_and_4100_performance_review,6.html
I'll be playing graphical heavy games. Like: Battlefield 3, Crysis 3, Dayz, Arma III but also be playing like Total War, Call of Duty, F1 2012. The less graphical games. So you could say I have a really big variety, but I'll be playing the more graphical heavy games the most,
I would shoot for the 965BE minimum, if you can stretch your budget a bit to the FX4300 please do as it gives a little bit more performance, here is a bench of both: http://www.anandtech.com/bench/Product/102?vs=700
It is anywhere from 6-10fps difference between the 965 and the fx4300, it really is up to your budget.
Since finding FX6100 benches is a pain in the behind, it does perform better then the FX4100 and the 965BE by a little. Here is a 8150 8 core from the same series agaisn't the 965BE : http://www.anandtech.com/bench/Product/434?vs=102
The 8 core is anywhere from 3fps-7fps better then the 965BE quad core, that speaks volumes for the bulldozer CPU's. If you really can not manage the FX4300 then get the 965BE you will not be dissapointed, i would never recomend getting a fx4100 or fx6100 or even the fx8150.
The system you listed really is a well rounded system, it will do very well for sure.
Well I looked at the price of the FX-8150 and almost got a heartattack :D. That thing is $165 compared to the 965BE ($86) The 965BE really does an astonishing job. And when I compare the 965BE with the FX-4300, it's almost 40 euro's cheaper. So it will be 965BE that has the honour to go inside my computer :D.
So this is the final conclusion:
CPU: AMD Phenom II X4 965BE (3.4Ghz, Quad Core)
GPU: Geforce GTX660Ti
MOBO: Asrock 970 extreme3
PSU: Corsair CX500 V2
RAM: Corsair Vengeance 8GB
One last question: Am I able to overclock the GTX660ti and the Phenom? I have the Cooler Maser Hyper 212 evo included in the list.
P.S The wheater is bagger over here, only snow and rain with winds reaching 50 Kilometer per hour.
