My laptop seems to be having a hard time mounting via autofs.
automount output from my laptop:
$ sudo automount -fvd
Starting automounter version 5.1.8, master map /etc/auto.master
using kernel protocol version 5.05
lookup_nss_read_master: reading master file /etc/auto.master
do_init: parse(sun): init gathered global options: (null)
lookup_read_master: lookup(file): read entry +dir:/etc/auto.master.d
lookup_nss_read_master: reading master dir /etc/auto.master.d
lookup_read_master: lookup(dir): scandir: /etc/auto.master.d
lookup_read_master: lookup(file): read entry +auto.master
lookup_nss_read_master: reading master files auto.master
lookup_read_master: lookup(file): read entry /-
master_do_mount: mounting /-
automount_path_to_fifo: fifo name /var/run/autofs.fifo--
lookup_nss_read_map: reading map files auto.media
mounted direct on /media/nfs/data with timeout 300, freq 75 seconds
do_mount_autofs_direct: mounted trigger /media/nfs/data
st_ready: st_ready(): state = 0 path /-
handle_packet: type = 5
handle_packet_missing_direct: token 113, name /media/nfs/data, request pid 8848
attempting to mount entry /media/nfs/data
lookup_mount: lookup(file): looking up /media/nfs/data
lookup_mount: lookup(file): /media/nfs/data -> -fstype=nfs4,rw,soft,intr,noatime,x-gvfs-show 192.168.1.25:/home
parse_mount: parse(sun): expanded entry: -fstype=nfs4,rw,soft,intr,noatime,x-gvfs-show 192.168.1.25:/home
parse_mount: parse(sun): gathered options: fstype=nfs4,rw,soft,intr,noatime,x-gvfs-show
parse_mount: parse(sun): dequote("192.168.1.25:/home") -> 192.168.1.25:/home
parse_mount: parse(sun): core of entry: options=fstype=nfs4,rw,soft,intr,noatime,x-gvfs-show, loc=192.168.1.25:/home
sun_mount: parse(sun): mounting root /media/nfs/data, mountpoint /media/nfs/data, what 192.168.1.25:/home, fstype nfs4, options rw,soft,intr,noatime,x-gvfs-show
mount(nfs): root=/media/nfs/data name=/media/nfs/data what=192.168.1.25:/home, fstype=nfs4, options=rw,soft,intr,noatime,x-gvfs-show
mount(nfs): nfs options="rw,soft,intr,noatime,x-gvfs-show", nobind=0, nosymlink=0, ro=0
get_nfs_info: called with host 192.168.1.25(192.168.1.25) proto 6 version 0x840
mount(nfs): no hosts available
dev_ioctl_send_fail: token = 113
failed to mount /media/nfs/data
handle_packet_missing_direct: token 114, name /media/nfs/data, request pid 8848
dev_ioctl_send_fail: token = 114
handle_packet_missing_direct: token 115, name /media/nfs/data, request pid 8848
dev_ioctl_send_fail: token = 115
handle_packet_missing_direct: token 116, name /media/nfs/data, request pid 8848
dev_ioctl_send_fail: token = 116
I know for a fact that it can reach that server as my laptop is able to reach it via SSH.
Both computer and server are on the same VLAN. The computer is able to mount the NFS share from my other server in different VLAN just fine.
autofs file in my laptop:
$ cat /etc/auto.media
/media/nfs/data -fstype=nfs4,rw,soft,intr,noatime,x-gvfs-show 192.168.1.25:/home
exports file from server:
/home/ 192.168.1.0/24(rw,sync,no_root_squash,subtree_check,crossmnt)
