Solutions to the fTPM stutter issue with unpatched BIOS/AGESA?
I have an AMD Ryzen 7 4700U laptop, hardware is fine except this issue, personally I don’t want to disable the TPM just yet, as I would like to setup automatic FDE unlocking at some point.
Acer are too lazy to support hardware for longer than a year so, so I’m stuck with a system that seems to lag periodically, especially during gaming, it’s not so bad when under-clocking, but sometimes you need the power.
Anyone tried a custom BIOS hack to update the AGESA or is there a way to trick runtime microcode updates on consumer products like you would with enterprise AMD products? Or should I just give up on the idea of using the fTPM for anything useful?
I believe there’s a few security related patches that I could benefit from as well.
