When I demolished your ridiculous assertion that you could run two trucks off a half-acre of flax I cited seven (7) different sources and used simple math that even a primary school kid could follow. If I have made some error or omission in the math, please let me know exactly where, and provide a reference for the correct value or method.
As long as you keep making assertions that are not backed up by anything, it is impossible to take you seriously.
Producing biofuel from grains like flax can be conceptually straight-forward, but you need vast amounts of land to produce the fuel in the quantities needed⦠and when you have to farm that amount of land you arenāt going to do with with a scythe and a seed press in an afternoon ā you need machinery worth hundreds of thousands to millions of dollars ā something you seem happy to overlook. At that point it is no longer viable to produce at the scale you are talking about.
There is a big difference between producing a cup-full of biofuel in a one-off experiment, and producing 1,536 gallons per year, as you would need to do. Just because you can do one does not mean that you can do the other.
The only people producing biofuel from grain the in the US are small religious communities (who donāt drive cars), and large companies who are exploiting the subsidy scheme offered by the government. Small-scale biofuel production from flax simply isnāt economically viable. You donāt qualify for the subsidy scheme at that scale. You are financially better off just buying dinosaur juice.
ā¦and thatās why no-one does it.
