Soft Brick On Tablet
So my friend has this cheapo tablet, a Dragon Touch Y88X, and while trying to unlock the bootloader, he soft bricked it, and has asked me to fix it. I can't find the factory images anywhere online, anybody have any idea what to do with it?
does it have a cyanogenmod image you could just install it
That was the first thing I checked. It seems to have no development whatsoever.
Find this hope it helps
http://support.tabletexpress.com/?model=IMGfiles&file=Y88.zip
I read cm9 works but the buttons don't work right .
Thanks Rui! Now I just have to figure out how to get it into fastboot mode.
fastboot or recovery mode?try the volume up button and the on button
I've tried that, hasnt worked. I could use fastboot or recovery at this point.
have you tried the down volume and the on button ?if it's mediatek you can use sp tool but this file there does not have a scatter (i downloaded it to check if it's actually a rom ) do you know how to make one ?
