So I was looking through my parts list and I noticed that the title for my CPU said LGA 1150, but then as I scrolled
into " Compare to Similar Processors ", in the CPU Socket Type it says LGA 1155. I just ordered my parts so I
began to worry. So I then went to my motherboard and again I scrolled down and it says the socket type is LGA 1150.. So do I need to get a different CPU?!?
I do not plan to overclock at least not at the moment, since I'm just coming from console so I'm still nooby when it comes to PC's but I know the minimal basic I guess you could say.
