I am working on my first custom PC build and I am really confused. I am hoping someone can help me out. I am trying to decide on a FX-4300 or 6300, I have been reading reviews and threads online but haven’t come to any concussion. In fact the more I read the more confused I am becoming.
Some people/reviews are stating the FX-4300 is better for gaming while others are stating the FX-6300 is the better choice. I will be using my pc for gaming and watching movies that is about it...I don’t plan on doing any photo-shopping or rendering. I just want to build something that is going to last 2-3years like my current one has.
Can anyone shed some light on this problem for me?
Well some game related benchmarks were showing the 4300 having a slight edge over the 6300 but I guess that can be attributed to the higher stock speed...I wish I had the room in my budget for the 8320 but with AMD’s new chip coming out sometime next year I just can’t convince myself of dumping that much into a CPU right now.
So far this is what I have picked out for my build
XFX Radeon HD 7950 Core ed. ASUS Crosshair V FORMULA-Z Samsung 840 Series 250GB XFX Pro 750W (Full Modular) Corsair Cooling Hydro Series H110 Patriot Viper 3 8GB 2X4GB
Looks great, though I personally would replace that h100 with an http://www.amazon.com/Noctua-Heatpipe-Bearing-Cooler-NH-D14/dp/B002VKVZ1A/ref=sr_1_1?ie=UTF8&qid=1366328581&sr=8-1&keywords=noctua
What I see here is a very premium build (high end mobo, and H100, 7950) and a CPU that is from a different category. I believe that with a sabertooth (that's still very premium) you will be able to get the 8350 and have the same overclocking experience.
If you want to keep it low priced, I would go for a m5a99 pro, a FX 6300 (which performs better than a 4300 even in games), cooled by a Dark Knight II, 8 gigs of ram and a really nice GPU, but I would never expend more money on mobo than on CPU.
I wouldn’t get the 8350 because the 8320 is basically the same with a lower stock clock speed (from what I am reading) which I will over clock anyway so I don’t see how the 8350 would be worth it in the end.
Oh and my cooler is a H110 (the 140mm version of the H100) :) http://www.corsair.com/en/cpu-cooling-kits/hydro-series-water-cooling-cpu-cooler/hydro-series-h110-280mm-extreme-performance-liquid-cpu-cooler.html
Now correct me if I am wrong. I THINK the AMD 8350 stock cooler needs to be upgraded?? I know when I build my 8350 I went with Liquid Cooler, Paid like 100 bucks for it.
There may be cheeper alternatives to the cooling issues of the 8350 and hope someone will come along and point them out.
I decided that I would just order a 8350 since it was on sale and just $50 more than the 6300 so I figured wth and like forsaken2011 mentioned why spend that kind of money on a high end mobo to pare it up with a mid range chip.
I would probably have gotten the 6300 but for $50 more for the 8350 seemed like a no brainer to me.
