So I'm trying to replace my Comcast modem and need help finding the correct replacement
So I need to replace a comcast modem (arris technology tg862g)...
Here is the docs on it..
http://www.arrisi.com/support/documentation/user_guides/_docs/TG862G-CT_User_Guide_Standard1-0.pdf
What is the best, open source if possible, option available to replace this with.
This. It is your best option
I removed the reference ID from AC1DSKU11's post so feel free to click mine
lol... thanks
thanks
I utterly hate the Comcast router; There is a spot reserved in hell for that piece of plastic. The Motorola surfboards are the best modems you can buy at a great price and I have never had any issues with mine.
I've always used my own modem with Comcast but be prepared for them to be a little reluctant to set it up (you have to call them and give them the MAC address). Also anytime you call in because of a problem, they will start to question your hardware setup NO MATTER WHAT you tell them. You could be a hardware/software developer at Motorola and explode their brains with your technical knowledge, and they would still doubt your setup.
