So to give the jist of the situation im in, I have a lg g3 and a backup of stock and on custom roms the data does not work, calling and texing do but not data, I restore to stock and give back to verizon and get another, same thing, I have no Idea what to do, side note, VZW Content filter is on, dont ask, paranoid mom. I guessing APN but dont know that much about it, looked into it before but could not figure out. Any help is appreceated. Thank you.
Youll need the right APN info otherwise it wont work. Cant say much more as ive no idea about verizon. But thats almost certainly why its not working.
Sigh, I cant believe I fixed it and could for months, used market enabler app and forced verizon, thank you for your help though!
I could probably guide you on how to fix the apn. Give me a few moments to find a guide.
APN Settings(There are two apns):
Apn one:
name: Verizon Internet"
mcc="310"
mnc="004"
apn="VZWINTERNET"
type="default,dun,supl"
protocol="IPV4V6"
roaming_protocol="IPV4V6"
Apn 2
mcc="310"
mnc="004"
apn="internet"
type="default,mms,dun"
mmsc="http://mms.vtext.com/servlets/mms"
protocol="IPV4V6"
