I was actually quite shocked when my monitor was still displaying DSR @ 4k after I just flashed a 4090 24GB 500 watt bios to my 4070… (I preset the power limit lower as to not fry my card in-case it actually worked and it started pulling 500 watts BECAUSE I have the P0 state forced.)
Dangerous right… Well yes it wouldn’t post with those settings lol, so I recovered it by using my AMD iGPU on my 7700x. I plugged my DP cable to my 4070 to my monitor and the Motherboards HDMI port to my monitor, cleared the RTC so it resets back to using iGPU, now I can see the bios from HDMI on my monitor (Basically dual monitors but it’s not, I have to select which one via the OSD).
Once I switched the BIOS settings to iGPU FORCED having both connected DURING a boot up is what saved it. I don’t want to talk about hot-plugged the 6+2. ![]()
Next subject. I was using HWINFO and the flash literally worked… that’s all I really have to say. The problem was it was a watercooled BIOS so only one fan worked LMFAO. (I’m retarded), but the device and SUB ID was SO similar to my 4070’s alternative BIOS (GIgabyte) to the 4090 that I had to try it.
With the power limit in MSI Afterburner at 50-70(I don’t remember exactly) I instantly saw 380watts and freaked the hell out for a second and lowered it all the way down to 30. Idle’d at 105-125watts. LOL
I kinda pushed what the internet’s dumb limits to see if my connector would melt, or even get warm. I ran the card for quite a minute at 350 watts shortly after and the connector was only slightly warm from the hot air blowing onto it… but the 4070’s hardware and everyone’s spreading of 150watt max misinformation had me second guessing myself.
Anybody flashed a 4090 bios to a 4070? I even started up Squad and was getting similar framerates but with a voltage of .875 instead of 1.1, and a clock speed of 2200Mhz instead of 3000Mhz or thereabouts I could get the clock speed to go up because of the curve by upping the power limit but then it would near 500watts and probably die… so this really interests me but I don’t know what kind of power limit I should run, as the card only has a 6+2 and it’s a stock PNY reference, as far as I know, dual fan GPU. Nothing special, well…tough as nails.
Personally I think the PCI-E can deliver 100 plus 300 from the connector (Corsair RM1000x btw). But if you google this stuff you either get some engineer spouting how to create a spaceship or the same stupid 150watt max crap which I can guarantee anybody that’s full of shite when I just ran 300 through one and it didn’t even get warm, only from the exhaust.
I found a Gigabyte BIOS with a 450watt baseline. Sounds feasible but dangerous and once again not sure if it would post…
Brb, gonna kill my card before anybody responds with experience.
