I ran it overnight and this is is what i saw in the morning after i let it run overnight.
NOTE: i stopped the test before this so the averagre test temp (load) was about 53C.
Look at the max temps. WTF?! That's hot enough to melt the solder.
hwmonitor is buggy there is no way you got 224c your cpu would be dead and the fx cpu will throttle down past 65c to keep the cpu down below 70c.
http://www.majorgeeks.com/files/details/hwinfo64.html
