So i just built my rig
Like the title,i just built my FX8350 rig. It;s running great. Well,great from a layman's view.
Now i want to know what kind of tests should i be running to ensure that my rig is indeed running all the components optimally?What software should i download to do this,if there is one?I'm not sure what prime95 does.What kind of tweaks should i be making in the bios?
Specs:
FX 8350
M5a97 evo r2.0
msi r7950
2x 4gb 1600hz kingston beast ram cas 9
These are the main components that can be tweaked for optimal performance.Thing is,how do i check for optimal performance?I have the 212 evo and will be OCing it later on once i'm more familiar with the inner workings of the rig.Using it right now to keep temps cool.
I've downloaded the msi afterburner software for the gpu,so i don't think i will have an issue there.
How do i go about OCing ram? CPU-Z shows my ram running at 800MHz at CAS 11. Does the speed change according to the load? And the CAS is 11 when i'm sure i bought it at CAS 9.Heck,even the packaging shows CAS 9.Is this normal?
Any help is greatly appreciated.Happy holidays!
The 212 Evo is an ok cooler(that's what it is a cheap ok cooler) but if you really want to get a solid overclock on an air cooler I would look at a d14 or equivalent.  Your bios will normally run automatic settings unless you manually set the values which I suggest you do as they are generally are never setup as advertised for your RAM speed and timings.  Prime 95 is used by most people for oc stability since it will stress you cpu far and beyond normal use.
If you do decide to oc your cpu most people oc using the cpu bus which also raises the speed of your ram, and most times you'll want to bring it down manually to the speed it was advertised at or sometimes below. Expect to spend a day on overclocking especially if you don't really know what your doing. Read up on guides and such there are tons of resources on how to go about ocing this processor.
completely agree with nihilyst.  You do however need to configure your ram to the correct timings and speed.  Go in the bios, not familiar with that board.  But most boards have the timings and speed for ram in the cpu configuration tab.  Do not overclock your ram out of the gate.  Make sure the ram is stable at its stock speeds and timings.
Thanks,guys.
I won't be OCing off the bat. Not looking for an aggressive OC as well.I'll be happy so long as the cpu does bot get choked up.Just want to familiarize myself with what's where and how to tweak,not the actual tweaking.
