SnowGecko's BSOD issue from SPAAACE!
Hey Everyone,
SnowGecko Reporting with My first forum Post.
My RIG
Gygabyte P67A UD7 B3 Rev. 1.0
Intel 2600K
16GB RipJaw Sniper 2133 Ram
2x GTX580's In SLI
2X OCZ Agility 3 120 SSD's Raid 0
1 WB TB Drive
1250 Watt OCZ PSU
The BSOD 000000000F4 Error
During the BSOD event Viewer gets a Critcle error. -Kernal Power-  41 Event
after many hours googles and pots of coffethe error seems to be SSD or hard drive related seems to happen when PC is Idel For long periodes of time.
Originally I build the PC with just one SSD then I got this error I replaced the ram and still same error I swaped SSD's and still same error so I Raided the 2 drives together and no error's for 3 months now the Error returns.
Now with that said I have Done the many SSD tweaks we know of such Ending paging files and so forth.
Please can anyone offer advise or thoughts?
after trying everything after 10 years of building PC's Something I could not fix. I broke down and took it to a local tech and NO BSOD's but as soon as I got it back BSODS continued.
My GURU's HELP please
upload the files from c/windows/minidump to a drop box. I have a more comprehensive way of reading dump files
Hey Commissar!!!!
Thanks so Much for your time I uploaded the .DMP to MF here is the link thank very much for any help
http://www.mediafire.com/?x24mjtxkgtmsl0a
could be the ssd, or a bad file in windows
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, fffffa801133b620, fffffa801133b900, fffff80003983460}
----- ETW minidump data unavailable-----
Probably caused by : wininit.exe
Followup: MachineOwner
6: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa801133b620, Terminating object
Arg3: fffffa801133b900, Process image file name
Arg4: fffff80003983460, Explanatory message (ascii)
Debugging Details:
PROCESS_OBJECT: fffffa801133b620
IMAGE_NAME: wininit.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: wininit
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: wininit.exe
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR: 0xF4_c0000005
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`07573e38 fffff800`03a0b822 : 00000000`000000f4 00000000`00000003 fffffa80`1133b620 fffffa80`1133b900 : nt!KeBugCheckEx
fffff880`07573e40 fffff800`039b7e0b : ffffffff`ffffffff fffffa80`12359060 fffffa80`1133b620 fffffa80`1133b620 : nt!PspCatchCriticalBreak+0x92
fffff880`07573e80 fffff800`03936f04 : ffffffff`ffffffff 00000000`00000001 fffffa80`1133b620 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176e6<br />fffff880`07573ed0 fffff800`03683253 : fffffa80`1133b620 fffff800`c0000005 fffffa80`12359060 00000000`029f0680 : nt!NtTerminateProcess+0xf4<br />fffff880`07573f50 fffff800`0367f810 : fffff800`036ceb7f fffff880`07574a38 fffff880`07574790 fffff880`07574ae0 : nt!KiSystemServiceCopyEnd+0x13<br />fffff880`075740e8 fffff800`036ceb7f : fffff880`07574a38 fffff880`07574790 fffff880`07574ae0 00000000`029f2190 : nt!KiServiceLinkage<br />fffff880`075740f0 fffff800`03683642 : fffff880`07574a38 00000000`0000aab7 fffff880`07574ae0 00000000`029f1c68 : nt! ?? ::FNODOBFM::`string'+0x488a4
fffff880`07574900 fffff800`036821ba : 00000000`00000001 00000000`029f0d98 00000000`772d2401 00000000`0000aab7 : nt!KiExceptionDispatch+0xc2
fffff880`07574ae0 00000000`771b8e3d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
00000000`029f0da0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x771b8e3d
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_c0000005_IMAGE_wininit.exe
What would you suggest I do from here?
Okay I have reinstalled Windows 7 a few times as for making the raid 0 and so on. So my first thoght is it's not windows. But could both SSD's have error's straight out the box?
Could it be the P67 Motherboard? I am understanding they had issues with SSD's?..... just a thought?
I swapped the SSD's drives and ram, this did not fix the issue.
Maybe a new version of windows?
never have I had this much trouble with a PC GoodlorD
BSODS are not my thing Please any advise would be greatly appreciated. Thanks
update firmware, might not solver your problem but its something that needs to be done
if that doesn't work, go here: http://www.techsupportforum.com/forums/f299/
they specialize in dealing with bsods
I attempted To do the Firmware update and sadly the OCZ firmware updater tool requires you to format all ssd's to be recognized to up date so I will need to spend several hourse backing up my data formating and testing this to get the firmware to update.
So i will keep you posted as things develope thanks so much for your help Syndicates
Okay I am fully up and running after the firmware update. As it turnes out, both drives were running off diferent Firmware but have now been updated to the ocz 2.25 SSD firmware. not only was there a minimal performance increase but i have been BSOD free thus far (Knock on Wood)
we will see how things progress in the coming days. again thank you all for the great help and advice.
no prob
Agility 3's are notorious for failing without newest drivers. You shouldnt have any problems now. Im almost 100% positive that will fix your problem. I used to use them all the time because there cost to performance, but they did fail until the most recent drivers.
Yes this problem is solved it would seem lol soooo directly after my last post I was off to bed feeling great about the PC I went to shut down the PC and
BSOD what ahh! (hanges head in shame)
NO not the same error
Stop code 0x9F
Driver Power State Failure
Minidump file I
                     V
http://www.mediafire.com/?ke2t6u463rvtc87
I am currently trying to update all drivers and seeking out a solution I have already done the google search and found an unasigned driver.
anyone familiar with this issue?
so many BSOD's
I would Like to extend my graditude to Commisar,TallGeese and GigabusterEXE for Your help after all your help I have been error free I am so very grateful thank you so very much. I had searched for answers everywhere, but it is here at Tek Syndacate where I found my answers. Your personal experience helped me so very much.
Thank You!!!!
hey, no prob. but if you have future bsods, go to the forum i linked to. the staff there are specialists at this sort of stuff.
I did :) they did help :) great advice :)
