Smartest (Non-Ceph/GlusterFS) Way for ZFS Pool Replication Across Cluster Nodes?
Hi all, hoping Level1Techs forums will finally help me in my quest for answers for this bunching of Proxmox/ZFS-related questions. No idea where else to turn after both the Proxmox forums and Reddit didn’t save my from my ignorance.
I previously asked this in both those places, but perhaps I couched it in too much detail and didn’t get much of a response (and I posted effectively this follow-up thread in both places and still didn’t receive much of a response).
Since the forum isn’t permitting me to share URLs in this post, here was my initial post seeking assistance:
Hi all, so I setup three Proxmox servers (two identical, one “analogous” - and the basics about the setup is as follows:
  • VMs and CTs are replicated every 15 minutes from one node to the other two.
  • One CT runs Cockpit for SMB shares - bind-mount to the drive pool with the datasets that are SMB-shared.
    • I use this for accessing folders via GUI over the network from my PC.
  • One CT runs an NFS server (no special GUI, only CLI) - bind-mount to the drive pool with the datasets that are NFS-shared (same as SMB-shared ones).
    • Apps that need to tap into data, use NFS shares (such as Jellyfin, Immich, Frigate) provided by this CT.
  • Two VMs are of Debian, running Docker for my apps.
  • VMs and CTs are all stored on 2x2TB M.2 NVMe SSDs.
    Data is stored in folders (per the NFS/SMB shares) on a 4x8TB ZFS pool with specific datasets like Media, Documents, etc. and a 1x4TB SSD ZFS “pool” for Frigate camera footage storage.
Due to having hardware passed-through to the VMs (GPU and Google Coral TPU) and using hardware resource mappings (one node as an Nvidia RTX A2000, two have Nvidia RTX 3050s - can have them all with the same mapped resource node ID to pass-through without issue despite being different GPUs), I don’t have instant HA failover.
Additionally, as I am using ZFS with data on all three separate nodes, I understand that I have a “gap” window in the event of HA where the data on one of the other nodes may not be all the way up-to-date if a failover occurs before a replication.
So after all the above - this brings me to my question - what is the best way to replicate data that is not a VM or a CT, but raw data stored on those ZFS pools for the SMB/NFS shares - from one node to another?
I have been using Sanoid/Syncoid installed on one node itself, with cronjobs. I’m sure I’m not using it perfectly (boy did I have a “fun” time with the config files), and I did have a headache with retention and getting rid of ZFS snapshots in a timely manner to not fill up the drives needlessly - but it seems to be working.
I just setup the third node (the “analogous” one in specs) which I want to be the active “primary” node and need to copy data over from the other current primary node - I just want to do it intelligently, and then have this node, in its new primary node role, take over the replication of data to the other two nodes.
This time after doing some digging I have some more focused questions that might help simplify the answer here.
Long story short:
  1. I have 3 nodes in a cluster, using ZFS.
  2. CTs and VMs are replicated across nodes via GUI.
  3. I want to replicate data in ZFS pools (which my CTs and VMs use - CTs through bind-mounts, VMs through NFS shares) to the other nodes.
  4. Currently using Sanoid/Syncoid to make this happen from one node to two others via cronjob.
So three questions:
  1. If I do Sanoid/Syncoid on all three nodes (to each other) - is this stupid, and will it fail - or will each node recognize snapshots for a ZFS pool and incrementally update if needed (even if the snapshot was made on/by a different node)?
    a. As a sub-question to this - and kind of the point of my overall thread and the previous one - is this even a sensible way to approach this, or is there a better way?
  2. For the GUI-based replication tasks, since I have CTs replicating to other systems, if I unchecked “skip replication” for the bind-mounted ZFS pools - would this accomplish the same thing? Or would it fail outright? I seem to remember needing to check this for some reason.
  3. Is PVE-zsync suitable for my situation? I see mention of no recursive syncing, which I don’t fully know what that means, and I don’t know if that’s a dealbreaker. I suppose if this is the correct choice - then I need to delete my current GUI-based CT/VM replication tasks?
Would so very, very badly appreciate guidance from those more informed/experienced than me on such topics.
Gentle bump, hoping for any guidance that might help me here! :pray: :
